Old 10-13-2009, 11:00 AM   #16
mblgjr's Avatar
Trader Rating: 86 (100%+)
Loose setup; slight rear brake bias; smooth throttle.
Red clay can show a groove like that and as moisture rises, the top will actually go really slick/greasy almost; which it appears to be that way. The clay in the vid. appears to be nice and damp, which aids in driving the car the way he does here.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 10-13-2009, 11:01 AM   #17
tc5 man's Avatar
ethier he has abs brakes or just going half throttle and steering a little and the track looks grippy i dont think u can do that when its dry and hard packed inless u have a smooth clutch setup
Old 10-13-2009, 11:27 AM   #18
mblgjr's Avatar
Only other note is that the JC Crosshairs on a truggy will let it float like that pretty easily.
Old 10-13-2009, 03:03 PM   #19
Look in his pit bag hes usually got 6 cans of tag body spray, I can get my car to behave just like that, just not consistently.
Joey Platinum is offline   Reply With Quote
Old 10-13-2009, 04:11 PM   #20
I am having a difficult time seeing any car in that vid, but their is a nice looking young woman.
jboehm is offline   Reply With Quote
Old 10-13-2009, 04:33 PM   #21
wfo
wfo's Avatar
Most pros run alot of rear brake it helps the car rotate quicker but takes skill.. If you can master it you will be faster.. most people run 50/50 or 40/60 with this your car will be a little more stable but is usually slower... lutz is the king of rear bias its like 25/75...
wfo is offline   Reply With Quote
Old 10-13-2009, 11:38 PM   #22
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
A huge part of it is tires and foams as well. I know Ryan loves to run the CrowBow setup with the new Profiled foams. The Crowbar in the front has amazing on power steering. This tire gives great on and off power steering but allows you to put the car wherever you want with a little throttle.
Then on the rear we usually run the Crossbows. The crossbows provide amazing forward bite but allows the car to rotate crazy hard. However, as soon as you lay throttle to the car it snaps straight and you are good to go. Look how well his car straightens up when on throttle.
Definitely take the tires into consideration.
Marcus
JConcepts/Werks Racing Engines/Ironman Bearings/PowerMaster Fuel/VP Racing
Black is offline   Reply With Quote
Old 10-14-2009, 01:14 AM   #23
Lonestar's Avatar
not sure about the rear brake bias helping that much... let's say that if he uses brakes as much as people seem to think here, they sure are biased to the rear to produce that effect.
I'm more enclined to think this is more like: VERY loose setup, ET-like throttle control... not that much use of the brakes.
As mentionned above by someone else, a lot of us can drive like this... for for 5 corners, then we clip the pipes whereas this guy can do it for 30mn in a row
awesome to watch. The guy doing his thing with the SC8 ain't bad either considering how this thing handles
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 10-14-2009, 01:47 AM   #24
slow coach's Avatar
do they look like regular width truck tyres to you ??
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 10-14-2009, 02:34 AM   #25
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
Marcus
90% i run this tire combo for a reason i drive hard and when your pushing to the edge of almost out control a set tires that hook and shot you stright are a god send but you still need enought steering to cork screw into the ground if you want it
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 10-14-2009, 05:53 AM   #26
JatoTheRipper's Avatar
Huh? I'm confused.
JatoTheRipper is offline   Reply With Quote
Old 10-14-2009, 06:01 AM   #27
petevette's Avatar
Send a message via Yahoo to petevette
Originally Posted by JatoTheRipper View Post
Huh? I'm confused.
Pretty JConcepts girl half way through the video.
petevette is offline   Reply With Quote
Old 10-14-2009, 06:25 AM   #28
Lonestar's Avatar
Huh? I'm confused.
Old 10-14-2009, 06:52 PM   #29
bjr48's Avatar
Marcus
I read a lot about this tire setup last year but don't hear anybody talking about it anymore. Those two tires look more similar to each other than I expected but see a couple of small differences that I think effect sideways traction and forward traction. Does anybody know what the equivalent AKA setup would be? I was wanting to finally try AKA next season due to all of the hype. Also, if you do this Crowbar/Crossbow setup do most people go with the same compound front/rear?
bjr48 is offline   Reply With Quote
Old 10-14-2009, 07:25 PM   #30
Ohhh! I didn't watch the whole video so I missed the girl. I'll have to look at it again.
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
Hot Bodies Cyclone D4 EP buggy Mike Schumacher Electric Off-Road 1921 10-06-2014 11:33 AM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
Jammin X1 - so close yet so far beetlebz Nitro Off-Road 4524 03-25-2012 01:54 PM
Suspension arm needs to be shimmed? bjr48 Nitro Off-Road 9 12-20-2008 05:20 AM
