Speed / Novarossi Rod?
#16
There are a few reasons Nova rods are expensive:
1. Nearly everything Nova makes is expensive. Yeah they do make some really cheap motors too but their top of the line stuff is all expensive.
2. Exchange rates.
3. I don't know what Italian labor rates are but I bet it's higher than Taiwan and maybe even Japan.
4. If you believe Nova's press, all their rods are checked for cracks and defects before they are shipped. This means you are paying for the expensive equipment to do the check, the labor and for all the defective ones that get thrown out.
5. Since Nova rods are the strongest on the planet (don't believe me, ask another experienced onroad racer) they obviously have some higher quality alloy they are using.
Of course, a lower quality Go rod is so cheap you could afford to replace it every race and still come out ahead.
2. Exchange rates.
#17
Oh, and as for Taiwan vs Italy on quality control believe me, Italy can make some real junk too. Just look at some of the old Fiats.
#18
Not true of Taiwan. Taiwan is capable of manufacturing to as high a standard as anyplace, they make exaclty what their client approves. Similar in China, if you see something here in the US that is "cheap Chinese junk", it was likely designed, approved and purchased by an American.
#19
Don't forget the Nova line of off road engines in 2007/2008 (not all but some, flame out kings), Nova off raod 367 plus series of engines $400.00 USD of pure rubbish..
#20
Fortunately I missed out on those. Every Nova built motor I have ever had has been fantastic except for one garbage JP. And I might have screwed that one up.
#21
That why I went with RB in '08. Didn't really think about the NR/Rb connection......never had any problems really with the RB after a gallon.
#22
But ya know, even my little nova B21 is made surprisingly well at its price point.They took solid design, but did no turbo cutting, or porting and put quality parts in it. It would be hard to beat with anything in it range. It truly has nuts, OK not 700 engine nuts but very nice. LMAO and even it has a 54 dollar replacement rod.......
#23
That last few 1/8th track i've been to were tight and technical. 25-30mph tops. Slipperey to. Just don't need big power. My+4 is collecting dust. Running my N21b with a 9886 and 41020. Deos well enough. Its weird seeing people run OS speeds on a tight track.
I might try a simple Turbo cut on the crank of the N21b (similar to the +4's) and maybe spend some time and cut some "fangs" on the sleeve. Nothing too crazy. Winters long.....................got dremel? I wonder if a WS7III crank would fit? I got one of those..........
Shoot, the Crank alone on a speed costs more than a whole N21b!
#24
#25
Just open up bothe sides of the crank inlet? Or is there a side in particular?
I'm going to stay away from the inside of the sleeve until I get better at this.
That, and I kinda what to see what each cut or two deos at a time.
#26
I've never had a degree wheel on an N21 so I can't say for sure but most likely it could stand to open a bit sooner and stay open for while longer as well. Crank timing is kind of trial and error anyway until you find the combo you like. Just don't go more then 1.5mm or so on either side and you wont kill it but without more exhaust duration to go with it you may not see much of a gain. Then again, it make it SCREAM, haha
#28
Rex
#29
Thanks, looks like I'll be learning to mod N21b cranks this winter!
#30
i know quality is the only issue with motors in opinions os speed is expensive but well made and parts are little cheaper where nova top end motor +4 is cheaper purchase with more expensive parts os rods are good cranks on reg. vspecs is soft but new ones are better also. it is all in the maker anyone who has known nova for extremly tight motors would think os vzb are no good cause do not carry alot of pinch after a gallon but run well if kept up right. the new +4 is the same as nova no super tight pinch but still run very good both are great and any country japan italy tiawan can make good product if paid right prob. is stuff is made in some places to save on laber costs
