Old 10-12-2009, 07:10 PM   #16
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Originally Posted by gotspeed_2000 View Post
Hows about the stock JX but also purchase the TKO ceramic bearings for installation after break in?
you would want to break the engine in with the bearings.. bearings havta seat and break-in too..
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 10-12-2009, 08:18 PM   #17
I would just want to break it in initially with the stock bearings, then toward the end of the break in put the ceramics in and let them finish off the break in. That way a little less load on the ceramics and hopefully a longer life with those little puppies in there.
I'm in the process of building the hybrid JX/Speed motor and will be initially doing the break in with the stock JX bearings. After a half gallon or so, I'm gonna switch it out to the TKO I have, and then finish off the break in with a few more tanks after the installation.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 10-12-2009, 08:20 PM   #18
Originally Posted by Frank L View Post
Great engine but you will want the eb mods head button and hats 60 bucks so you might as well get the modded version it comes with the head button.
Does the EB mods version also come with TKO's? If so, that sounds pretty darn good.
Old 10-12-2009, 08:23 PM   #19
jpalessi's Avatar
the engine is good to go after a quart.
No tko's
Joe Alessi
www.Lucky7RC.com
Old 10-12-2009, 08:30 PM   #20
Mr. Twister's Avatar
if i was a racer looking at the two, i would go with the EBJX hands down, the promod has no reworking of any of the internal part's, stock button, stock rod, stock block, speed crank with a single slug last time i looked, much more empahisis on creating power than just a milled head and the same crank used in 3 different motor's, the JX is flat out hard to beat.
Brian Carey
615-838-5373
Tennessee Oval Performance
Check us out on Facebook
Mr. Twister is offline   Reply With Quote
Old 10-12-2009, 08:34 PM   #21
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
I had nothing but bad luck with my V-Spec. Some of the posts here illustrate why I am frustrated with the V-Spec. It's a great motor...
  • if your crankcase doesn't crack
  • if your front bearing doesn't leak
  • if your crank pin doesn't go out of round
  • if you replace the head button for another $60
  • if you replace your bearings with ceramics for $50
  • if you replace your conrod after break-in
  • if you don't touch your mid-speed needle
All of these "issues" are quite common.
Yeah, lots of if's. Did I mention that I have seen 5 different "default needle settings" for the 21J carb that currently comes with the V-Spec, no one can seem to agree on the right settings.
Of course, you may have different luck. I know people who love the motor, and those that had nothing but issues.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 10-12-2009, 08:35 PM   #22
Frank L's Avatar
Trader Rating: 148 (100%+)
There it is spoken from an engine modder himself and hes telling you to buy the competition's engine not "get one of mine". I would take Brian's advice I have seen what he has done for a friend of mine and he knows his stuff. I think you have your answer Ninja.
Old 10-12-2009, 09:01 PM   #23
jpalessi's Avatar
+1 Stand up guy that Pro Twister..
really tho he's just tellin you the truth as he has no reason to lie, and I couldn't agree with him more.
If ceramic bearings is your concern just get TKO's they're only like $40 for the set...
Joe Alessi
www.Lucky7RC.com
Old 10-13-2009, 03:36 PM   #24
tony montana's Avatar
Trader Rating: 65 (100%+)
the stock ninja does not need any mods of any kind
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 10-13-2009, 05:12 PM   #25
Frank L's Avatar
Some guys like modded engines some guys don't personally I do. I had mark at powerhouseperformancerc.com mod a couple grp's and they were like completly different engines. So to each his own.
Old 10-14-2009, 05:07 AM   #26
TonysScrews's Avatar
Originally Posted by HiVoltg12 View Post
http://www.amainhobbies.com/product_...n-Buggy-Engine
or
http://www.tonysscrews.com/product.s...&categoryId=74
Going in a RC8T. People I race with say to go with the V-Spec Pro Mod. They say it's smoother and easier to tune than a Ninja. I like that the Ninja is modded and broken in for $20 more than the V-Spec. No ceramic rear bearing though...
What do you think...Would the Ninja be better? I race on medium size tracks and I'm looking for good usable power throughout the rev range. I can't decide...
Hi,
Check out the JX21 thread. I'm offering FREE shipping on the EB Mod JX21-B01A engines I have left in stock (US only). If you are outside the US I'll discount the motor $10 USD.
Best regards,
Tony P.
Tonys Screws LLC
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
