Old 10-11-2009, 07:59 PM   #1
Default Maintenance Question Shocks & Diff Oil
If this question has been asked before I apologize. I searched the forum but came up empty.
I'm certain that the questions below are elementary in nature.
Buggy: Losi 8ight 1.0 RTR
How often should the oil in your shocks be changed, if they do not appear to be leaking or low?
How often do shocks typically need to be rebuilt? I'm assuming when they start to leak, but not certain.
I am also assuming that the differential oils should be changed at regular intervals? How do you know when they require changing?
Some friends and I race on a dirt track every 2 to 3 weeks, and average about 1.5 to 2 hours of actual run time each time out.
Thanks for all the information
tk1931 is offline   Reply With Quote
Old 10-11-2009, 08:05 PM   #2
Jason-149's Avatar
I usually change out the fluid in the shocks every 3 to 4 races. Diffs maybe every 6 to 8. Actually rebuilding the shock with new pistons, bladders, and o-rings around 3 months or so depending on how you drive and how much you drive. your pistons will develop a small amount of slop in them over time and make the dampening a little less inconsistant.
TLR / Horizon Hobby / Spektrum / Upgrade R/C
Jason-149 is offline   Reply With Quote
Old 10-11-2009, 09:16 PM   #3
thenova70ss's Avatar
Trader Rating: 52 (100%+)
I rebuild my shocks every Gal and my diffs every 2 gal and new bearings in the hole buggy every 3 gal. And i might rebuild the hole buggy Shocks Diffs and Bearings if we have a big race coming up.
CHRIS CREWS
Pro Speed Racing Optima MX1 Buggy http://www.global-hobbies.com.my
Cold Fusion R/C Products Team Driver - www.coldfusionrcproducts.com
Rc Pro ProDucts Team Driver www.rcproproducts.com
Hobby Pro USA Team Driver www.vp-pro-usa.com
thenova70ss is offline   Reply With Quote
Old 10-11-2009, 11:49 PM   #4
slow coach's Avatar
also depends on the track, if its very rough the oil gets worked much harder and will benefit from changes more often to a degree the same goes for the diffs.
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 10-12-2009, 05:23 AM   #5
jamiekerr14's Avatar
Im from the UK the track I run on it pritty bumpy.. gives the shocks a real workout.. I normally change them ever 3-4 days of use.. Or before a big event.. But Im a club racer at the moment.. dont have the or time to travel far to race. -Yet!..
But I generally change shock oil after 3 or so days use.. or before a big event. Sometimes before a club meet.. if Im bored lol mainly for better piece of mind..
Diffs, I change maybe every 4-5 days use.. or again before a big meet. But generally check them after 2 days use... to see if they need changing, and that there working well.. not leaking.. sometimes top them up.. but thats me. Some change it after ever day.. some gallon or so.. I think alot depends on your budget and time.. Its a bit more changing after every day.. but the car will be very consistant.. being fresh oil each day.. but I think generally most change them after 3-4 days... but each to there own.. I guess..
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 10-12-2009, 10:06 AM   #6
shanty140's Avatar
I change the fluid in my shocks every 3 races including some practice run time. Works out to be about 3 hours of run time. I change my diff oils about every month and a half which is about 6 races. Again works out to be about 6 hours of run time. Usually I replace before hand because I got a big race coming up where I replace everything that has some wear. I replace the o-rings, bladders, etc every big race which usually is about every month. I replace bearings all the time. The ones in the carriers after every 1-2 runs. The diff bearings I replace every month usually before a big race. Bearings in the steering assembly can last a long time, I check them everytime I go through the truck and check them.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Savx SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 10-12-2009, 10:11 AM   #7
climbaatizept's Avatar
I change my Shock Oils every 2 races, and change de Diffs Oils every 5 or 6 races..
Kyosho MP9 / Team Durango DEX210 / Team Durango DEX410 / Hyper Rally Game / Truggy
Alpha Engiines / Schepis Model Engines /Multiplex /Spektrum /Runner Time Nitro
climbaatizept is offline   Reply With Quote
Old 10-13-2009, 07:10 PM   #8
Thanks for all the great information.
Old 10-13-2009, 07:38 PM   #9
NuthinFancy91's Avatar
I re-oil my shocks every 6 races, and diffs every 6 races...
Johnson Racing Team #94
Blue Groove R/C Apparel
Rccna Racing Team
Team Losi
NuthinFancy91 is offline   Reply With Quote
