Old 10-10-2009, 08:29 PM   #1
Default spur clutch bell noise
built a brand new truggy, but the there is noise metallic noise coming from the clutch bell and spur when I roll it on the ground. Tried to tighten, loosen the mesh, but it makes that sound regardless. No amount of shims for the clutch bell made any difference. The clutch bell spins very smooth. The gears seem ok, with no burrs, or any distortion. It does not make that sound when there is nothing meshed to the spur. Is there something wrong or that is just the way it is?
here's a vid for the sound
+ YouTube Video
inpuressa is offline   Reply With Quote
Old 10-10-2009, 08:34 PM   #2
tc5 man's Avatar
your gear mesh is to tight just adjust it to have a tick of play,or your clutchbell teeth have a burr on it
tc5 man is online now   Reply With Quote
Old 10-10-2009, 08:37 PM   #3
Trader Rating: 29 (100%+)
+ YouTube Video
somethings binding somewhere but i couldnt tell you. maybe someone else can help ya out!
kyosho mp9:novarossi 21-4C, nova 2084, 7955TG, dx3R
slayyer is offline   Reply With Quote
Old 10-10-2009, 08:46 PM   #4
Euro Stealth's Avatar
Could also be your center dif since that was also in the main focus of the video, hard to tell with a discription, and even the video, but check to make sure your dif mesh is good, and that you are shimmed correctly, and that you even have the right about of oil in the dif.
Also check out the mesh of the clutch bell/spur like stated above!
Brandon Ryan:
Thank you!
*The Speed Shop*JConcepts*Blue Groove Apparel*Kustom RC Graphics*
Euro Stealth is offline   Reply With Quote
Old 10-10-2009, 08:53 PM   #5
losi_racer's Avatar
Trader Rating: 25 (100%+)
sounds to loose to me
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 10-10-2009, 09:19 PM   #6
I know I can get the mesh perfect. I always get them right on my 64 pitch gears Upon closer inspection, it seems that there is a bind whenever a tooth goes over a certain tooth on the clutch bell. It feels like there is a notch or something. But when I look at it, it seems to look perfectly fine. At this point, maybe I'll just run it as is, and hope that whatever it is will wear into shape?
Old 10-10-2009, 09:21 PM   #7
smokinu's Avatar
Trader Rating: 60 (98%+)
buy a new clutch bell if that done fix the problem buy a new spur if that dont fix it buy a new truggy.
looks like a trf801xt too top of the line should have got the mbx6t
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 10-10-2009, 09:22 PM   #8
Cory Kerber's Avatar
What your describing is exactly what happens in new Berg crawler axles. They seem to bind up at certain spots. Once you run them and break them in, they're fine.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 10-10-2009, 10:00 PM   #9
allan42r's Avatar
its your mesh, or tiny baseball cards in the spokes.lol sounds like you have the mesh too tight.
Pinky kisses better than mason's mom
allan42r is offline   Reply With Quote
Old 10-10-2009, 10:46 PM   #10
its that one particular tooth. like I stated at the op, doesn't matter if the mesh is tight or loose. The driveline has no drag to it, so I guess I'll just run it and hope that the tooth will wear down. The current mesh is so I can rock the spur back and forth 360deg. Pretty much I use to do my 32 pitch gears.
In the meantime, anyone can suggest me a good replacement clutch bell?
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
CEN Matrix TR t4usee Nitro Off-Road 1798 03-29-2010 09:57 AM
Slipper clutch problem? BradT041 Monster Trucks 24 03-23-2007 09:08 AM
