Old 10-10-2009, 06:02 PM   #1
smokinu's Avatar
Trader Rating: 60 (98%+)
Default Weird Motor problem..
Ok so i am using the caster Go tech Grenade...
in my hot bodies d8 with clutch set up is stock springs with 2 answer alum shows and 1 stock shoe.
it has a go engines femca 0801 matching pipe.
Tuning this beast the other day.... i noticed that when i let off the throttle it would still rev a bit before returning to idle...
she ran good with great out of whole punch and a good puff of smoke after a 6sec idle to wfo.... should i drop all 3 alum shoes in or go back to all 3 stock carbon shoes.
or is it a tune issue...
i can get a vid maybe...
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 10-10-2009, 06:08 PM   #2
Check your fuel line closely, sounds lean. Look at your exhaust gaskets closely. Stop running it..... do not make the same mistake I did.
Joey Platinum is offline   Reply With Quote
Old 10-10-2009, 06:09 PM   #3
smokinu's Avatar
its not lean though.... its making tons of smoke on the low end into the high speed temps after about a 1/2 tank of running was 210 and thats cold for the grenade
Marcus P.
Old 10-10-2009, 06:11 PM   #4
Does the idle come back down after a couple seconds or stay up?
-Losi 8T 1.0 mutating to 2.0
Spektrum DX2.0, Werks B5
Samson4721 is offline   Reply With Quote
Old 10-10-2009, 06:12 PM   #5
blktransam's Avatar
Trader Rating: 59 (100%+)
I am sure I will get told to get out of the thread as I do not know how to tune a engine..but I will give it a whirl
does it idle down due to the low end loading up? like it will hold a high "idle" for a couple seconds then drop down I have found its due to a rich low end causing the engine to idle down from loading up...
if so lean out the bottom end until you get a steady idle then drop the idle down via the idle air gap screw
just my 2 cents
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 10-10-2009, 06:20 PM   #6
I'm not going to tell you anything .... cause I understand your situation perfectly. I can not say that you were at fault. I can only say that I believe you know how to tune and the engine did not respond to your adjustments.At least you did not damage the internals with your tuning or wrenching, you only damaged the back plate which normally would not have been a problem.Some of the guys on here feel a strong bond with distributors and defend them. nothing wrong with that either.I am glad you are on here helping people out.
Old 10-10-2009, 06:21 PM   #7
DPowers's Avatar
Trader Rating: 79 (100%+)
just my 2 cents
for someone who dont know how to tune an engine you sound right to me i do believe the low end is a little rich you might need to lean it in a few hrs and turn your idle down but i will tell you my freind runs the same engine and he blew a rod in 2 of them at the S.I.C i believe he was running them to leane so i would run them a little rich.
DPowers is offline   Reply With Quote
Old 10-10-2009, 06:29 PM   #8
blktransam's Avatar
Joey not bringing my other thread in here lets keep it in that thread ...I will always try to help others as I always have.
just to show ya last indoor season one of the local guys blew up his engine during practice and no one would lend him a spare to finish the race day. I had a brand new orion .21 (same as jpx .21) pulled it from the box told him to stick it in his car idle one tank and race tune it...lol and he did and I got like 6 gallons out of it lol he was very grateful for it and anytime I have needed something he has been the first to step in and try to help me.
anyways smokin if u take my advise great if not I understand. but to me thats what it seems like the issue is from the info you gave
-Ryan Klemme
Old 10-10-2009, 06:30 PM   #9
Also check your servo to make sure you don't have the idle resting on the trim ....if so when you hit the brakes it could stall??? or speed up when off the brakes???
Old 10-10-2009, 06:37 PM   #10
race raider's Avatar
Trader Rating: 38 (100%+)
just my 2 cents
+1 I just had the same problem and this is how I fixed it
1 Corinthians 2:2 for I resolved to know nothing while I was with you except Jesus and him crucified.
race raider is offline   Reply With Quote
Old 10-10-2009, 06:45 PM   #11
smokinu's Avatar
no it will drop to a low idle as soon as the car comes to a stop.
just my 2 cents
i have no problem with you helping me out ryan.. i know it was not your tune that ruined a back plate.
i have blown one rod due to a lean bottom have to watch that thing close! but this engine ran 419 degrees and still runs like a champ!
i will take your advice thanks for helping.
you know how stupid i am haha it was the servo... not fully closing the idle gap when i let off.. but when i slammed on the breaks it would drop to a really low idle.
cool deal.
Marcus P.
Old 10-10-2009, 06:46 PM   #12
houston's Avatar
Trader Rating: 91 (100%+)
i will say the go carbs (unless fixed) leave a little room for improvement .
so hard to say as there are many variables but usually a tad lean on low if after full throttle applied and engine revs up a little then idles normal in less than 3-4 seconds . if the engine idles up and then has a nice blubbery sounding idle for more than 3-4 sec. then it is usually rich with too large of an idle gap . too lean lsn leaves engines with tingy sounding idle and usually minor lean bog when running unless overcompensated with richer than normal hsn . like i said , could be one of many things though . like said before , sticky carb or linkage .
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-10-2009, 06:51 PM   #13
blktransam's Avatar
glad to hear you got it fixed! I thought that but didnt see u post about applying brakes to make the idle drop.
-Ryan Klemme
Old 10-10-2009, 06:56 PM   #14
Zerodefect's Avatar
Whoa.....hit it right on the head!
Grasshopper says someones engine building/tuneing Kung-fu is improving
I see that you've created an OS Speed out of blown up engine parts. Your skills as a Jedi are now complete.
Zerodefect is offline   Reply With Quote
Old 10-10-2009, 07:00 PM   #15
I had this problem with an RB WS7. I finally found the leak today. It got progressively worse; from running on at the end of a straight to the point that I can now basically turn laps without touching the throttle. I could take the throttle servo out entirely and turn laps.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Trinity Pulse motor Drift Demon Electric On-Road 240 05-17-2012 01:45 PM
Motor Problem.... Gearhead racer Nitro Off-Road 6 07-15-2009 02:46 PM
Trackside Pre Race Motor Inspection!! not home Wisconsin & Illinois Racing 22 03-25-2008 01:14 PM
Krypton motor problem. rcpilot Electric On-Road 30 07-09-2003 12:05 PM
weird ko propo servo problem VenomWorldOrder Australian Racing 6 01-09-2003 02:21 AM
