Old 10-10-2009, 07:02 PM   #16
Zerodefect's Avatar
Weird, where was the leak.
Zerodefect is offline   Reply With Quote
Old 10-10-2009, 07:03 PM   #17
You know what is funny .... I'll be on here next week with the same problem and won't remember the fix.LOL
Joey Platinum is offline   Reply With Quote
Old 10-10-2009, 07:21 PM   #18
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by Zerodefect View Post
Whoa.....hit it right on the head!
Grasshopper says someones engine building/tuneing Kung-fu is improving
I see that you've created an OS Speed out of blown up engine parts. Your skills as a Jedi are now complete.
yes you must snatch pebble from my hand first
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-10-2009, 07:58 PM   #19
smokinu's Avatar
Trader Rating: 60 (98%+)
Originally Posted by houston View Post
i will say the go carbs (unless fixed) leave a little room for improvement .
so hard to say as there are many variables but usually a tad lean on low if after full throttle applied and engine revs up a little then idles normal in less than 3-4 seconds . if the engine idles up and then has a nice blubbery sounding idle for more than 3-4 sec. then it is usually rich with too large of an idle gap . too lean lsn leaves engines with tingy sounding idle and usually minor lean bog when running unless overcompensated with richer than normal hsn . like i said , could be one of many things though . like said before , sticky carb or linkage .
Monty i have done my home work i just replaced the orings in the carb today.. (a bit bigger with some greese on them) to prevent the lsn from creating the air leak
will test my progress tomorrow its to late to run a nitro here in the city.
Originally Posted by blktransam View Post
glad to hear you got it fixed! I thought that but didnt see u post about applying brakes to make the idle drop.
well actually if i go wot and let off it will slow down like a jake break kinda thing its kind of funny to hear.... but it always returned to idle but thinking back yesterday while running it when i did slam on the breaks it brought it to an idle very quick.
Originally Posted by Semple View Post
I had this problem with an RB WS7. I finally found the leak today. It got progressively worse; from running on at the end of a straight to the point that I can now basically turn laps without touching the throttle. I could take the throttle servo out entirely and turn laps.
now thats just bad.
haha Monty do you break in jammin motors? i want my jpx .21 plus done right..
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 10-10-2009, 08:35 PM   #20
Zerodefect's Avatar
My N21b makes that sound as well.
We have a chicane at the end of our straight that I coast into. Coasting after full throttle like that kind of makes it go: eeeeeeeeee, pop, pop, pop, eee
Usually means somethings a little lean or idle is set too high and its rich. But I can't richen my low end anymore, maybe I can richen the top 1 hr. The track has a short straight and is technical so my our tunes are a little odd. Big track but no power is really needed to get around it.
As long as my engine deosn't sig for no reason in the air, " wheeeeeee" sound, I'll let the weird coasting sounds slide.
Old 10-10-2009, 08:51 PM   #21
smokinu's Avatar
its not like a lean bottom sound its just like it hesitates to drop down to idle sound like your slightly still on the throttle... should be fixed
but i dont think i am racing tomorrow anyways so i dont think it really matters.
Marcus P.
Old 10-10-2009, 09:03 PM   #22
losi_racer's Avatar
Trader Rating: 25 (100%+)
marcus, my dads did this. it was rich on bottom
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 10-10-2009, 09:05 PM   #23
smokinu's Avatar
if i dont race tomorrow ill toss my tune tires on and get it solved.
Marcus P.
Old 10-10-2009, 09:10 PM   #24
allan42r's Avatar
tune tires? do they say acme on them and are they used to chase a road runner?lol
Pinky kisses better than mason's mom
allan42r is offline   Reply With Quote
Old 10-10-2009, 09:14 PM   #25
houston's Avatar
now thats just bad.
novarossi ? yes i do novarossi engines
Old 10-10-2009, 09:17 PM   #26
smokinu's Avatar
i have some road tires from hong nor that i run for street tuneing instead of blowing a pair of 40 doller aka or panther or proline tires on the street.
Marcus P.
Old 10-10-2009, 09:19 PM   #27
smokinu's Avatar
boo i guess ill just break it in my way wot out of the box....
done my 18tz that way she had 5 gallons when i sold it and the guy that i sold it to is still racing it!
wait if i de ano the head pc it purple and put a nova carb on it will you break it in for me? jk jk!
Marcus P.
Old 10-10-2009, 09:25 PM   #28
allan42r's Avatar
yea i think we all have tires for this. CARtune tires,lol,sorry just trying to add some humor.
Old 10-10-2009, 09:28 PM   #29
smokinu's Avatar
haha
Marcus P.
Old 10-11-2009, 04:52 AM   #30
j_blaze14's Avatar
Trader Rating: 34 (100%+)
i had that happen twice, you try to fatten the bottom but it goes from super lean to super fat for no reason. top is good but temps get high anyways. check the case where the mount screws go and see if there is "silver slime" around them. i cracked 2 cases on the left mounting wing.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Trinity Pulse motor Drift Demon Electric On-Road 240 05-17-2012 01:45 PM
Motor Problem.... Gearhead racer Nitro Off-Road 6 07-15-2009 02:46 PM
Trackside Pre Race Motor Inspection!! not home Wisconsin & Illinois Racing 22 03-25-2008 01:14 PM
Krypton motor problem. rcpilot Electric On-Road 30 07-09-2003 12:05 PM
weird ko propo servo problem VenomWorldOrder Australian Racing 6 01-09-2003 02:21 AM
