Old 03-25-2011, 07:43 AM   #16
Originally Posted by portyansky View Post
How many shims are you using? I just did my rear (Thats where i was having issues) and I had 1 on each side, but I took one off of one side and now have 2 on one side and none on the other. Its not tight, but it seems that there is no play and is very smooth. Gonna inspect the front...
Having 1 on each side is defeating the purpose of shimming it.You want it on the ring side so it takes the slop away and puts the ring gear closer to the pinion.Usually, if your using 2 shims already and it still has too much backlash, then your gear casing is wore out.Best bet is just to replace the casing and start fresh. Once the pinion and ring gear start going bad from being too loose it gets a little bit more expensive to replace than just the gear casing.
Sholler is offline   Reply With Quote
Old 03-26-2011, 06:02 PM   #17
portyansky's Avatar
Trader Rating: 54 (100%+)
Originally Posted by DanELITE View Post
this helps i ges ill try 2 on one side. i dont thank it will work but ill try it.
This thread is 2 years old. Since this thread I have ran 2 shims on the gear side in my truggys and buggys with zero issues.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
New XRAY 808 Philipm Nitro Off-Road 12372 12-08-2015 06:43 AM
kyosho electric offroad b-man777 Electric Off-Road 9014 12-22-2012 07:36 AM
HPI Hellfire SS Kit Build & Long Term Review MadHacker Nitro Off-Road 586 07-06-2011 12:26 PM
Kyosho diff question...help a brother out!!!!!!! themanimal Electric Off-Road 14 04-27-2006 05:22 PM
