Old 10-08-2009, 09:42 AM   #1
Default Air bubbles?
I keep getting air bubbles in my fuel line. I have replaced the fuel line the tank isn't leaking. Its a losi eight with a sts .21 engine. Any ideas would be appreciated. Thanks
Twisted Nitro is offline   Reply With Quote
Old 10-08-2009, 10:21 AM   #2
madweazl's Avatar
Is the fuel supply line touching the pipe? My RTR came with the fuel supply line running through the lower mounts which had it close to or touching the pipe. I swapped it to the upper mounts and dropped the pressure line to the lowers. I didnt have problems either way but it is something to check.
If that doesnt fix it, perhaps the tubing has a leak or the clunk is stuck.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 10-08-2009, 10:32 AM   #3
Euro Stealth's Avatar
You may not THINK that your tank is leaking, but that doesn't mean that it is not letting air in. Your carb could have a leak as well, have you removed your carb and sealed it?
Brandon Ryan:
Thank you!
*The Speed Shop*JConcepts*Blue Groove Apparel*Kustom RC Graphics*
Euro Stealth is offline   Reply With Quote
Old 10-08-2009, 11:01 AM   #4
madweazl's Avatar
Leaking carb wouldnt make bubbles in the line, right? I wouldnt think a leaking tank would make bubbles in the line either since it's pressurized by the exhaust but I guess it happens.
RadioPost
Old 10-08-2009, 11:45 AM   #5
Echelon's Avatar
Check the external fuel filter, if you use one. Mine caused bubbles.
Echelon is offline   Reply With Quote
Old 10-08-2009, 11:48 AM   #6
smokinu's Avatar
Trader Rating: 60 (98%+)
NO NO NO NOOOOOO MY BUBBLES MY BUBBLES!
omg having little kids around hehe
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 10-08-2009, 12:26 PM   #7
I don't run an external filter
Old 10-08-2009, 12:40 PM   #8
smokinu's Avatar
i run 2 plus the one in the tank.
Marcus P.
Old 10-08-2009, 01:33 PM   #9
My Xray 808 had that problem once in a while. Never did figure it out. Didn't matter what tank, pipe, engine or fuel lines I was using, it would just happen.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Air Bubbles in Shocks? Chris__RC Nitro Off-Road 10 01-23-2009 05:00 PM
air leak? ruggydriver Nitro Off-Road 7 10-18-2008 12:19 AM
air bubbles in the fuel line hobdog Nitro Off-Road 19 08-28-2008 04:34 PM
ride air remover RP600 stephen hilton Electric On-Road 22 04-08-2008 03:06 PM
air bubbles in fuel line jackhammer74 Monster Trucks 6 07-01-2005 10:08 AM
