Old 10-07-2009, 04:07 PM   #1
alexrckid's Avatar
Default JPX .28 bearing size...
anyone know what size front/rear bearings are in the Jammin .28..??
alexrckid is offline   Reply With Quote
Old 10-07-2009, 04:20 PM   #2
ScottyM's Avatar
Trader Rating: 27 (100%+)
7x19 front
14x25.4 rear
Check Boca bearing to make sure.. They have a reference chart that helps.. Jammin is a picco based motor and the picco .28 has the above bearing demensions..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 10-07-2009, 05:51 PM   #3
Peter Martin's Avatar
Those are correct.
Peter Martin is offline   Reply With Quote
Old 10-07-2009, 06:03 PM   #4
alexrckid's Avatar
thanks guys...PETER...do you have bearings of those dimensions in CERAMIC..??
Old 10-07-2009, 09:48 PM   #5
Yes we do.
www.tkocompetitiondev.com
Old 10-08-2009, 07:06 AM   #6
you can get those bearings here in ceramic
bocabearings.com/main1.aspx?p=product&id=3502&n=*ENK-148C-MX
this engine can be particularly problematic on bearings. we designed a special MX series with a slightly different internal configuration to take more loads. if you are having trouble with your stock bearings the MX bearings should fix the issue for you.
in the future you can always do a search here by make/model/engine size:
bocabearings.com/main1.aspx?p=quicksearchkit&cat=2
or browse our cross reference guide:
bocabearings.com/main1.aspx?p=showsubcat&cat=crossref&pg=2
hope that helps, let me know if you have any questions.
Jflanzbaum is offline   Reply With Quote
