Old 10-06-2009, 06:41 PM   #16
rangerjkb's Avatar
Trader Rating: 39 (100%+)
Send a message via MSN to rangerjkb
Last season, I saw 2 new Werks B7 Pro's give way, very similar to yours. One in Truggy and one in Buggy, both drivers were very seasoned tuners, could possibly be the engine itself?
JB
rangerjkb is offline   Reply With Quote
Old 10-06-2009, 07:15 PM   #17
wingracer's Avatar
Trader Rating: 23 (100%+)
JB
Yes and no. Garet you have a PM. I would rather keep my thoughts private on this one.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-06-2009, 07:22 PM   #18
ive heard nothin but bad things about werks motor
rc-pro racing in gloucester va/TEAM TERRIBLES
ST-RR/8ight 2.0
osspeed,ebmods pipe,trinity platinum 30%,dx3r
crawldad91 is offline   Reply With Quote
Old 10-06-2009, 07:35 PM   #19
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Originally Posted by wingracer View Post
To all the people saying he was running too lean, that's possible but not necessarily true. Rods will often stretch or wallow out the lower bushing before they let go. When this happens, the piston comes up higher, increasing compression and causing the detonation that pitted the head and top of the piston.
As for what you did wrong, when a motor that has been running fine starts to kill plugs, STOP RUNNING. 9 out of 10 it's a rod about to go, the remaining 1 being either a rear bearing or worn out crank pin.
What motor was this and how old was it?
this is true but what do you think makes the rod bushing "wallow out" as you say... RUNNING LEAN! I ran siro based engines for almost 2 years and NEVER replaced 1 rod,,, bearings yes, but never a rod... with exception to the bearings and carbs i put star based engines at the top list when talking about quality.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 10-06-2009, 07:44 PM   #20
jpalessi's Avatar
Originally Posted by Garet Jax View Post
If this is trully the problem, then is this fixed richening the HS needle or LS needle?
These engine tend to be ran lean on the bottom cause they take longer to warm up, so ppl start leaning the bottom to get a strong idle and good snap right off the bat.. then 3-4 mins into your qual it'll start to get hot and feel soft.. best advise i could give you is with any Italian engine be out there the start of the heat before yours warming your engine up for 5 mins.. when you first start the engine and it's cold it won't idle THIS IS NORMAL! once the engine starts to get warm it'll start to idle no prob... when you tune these engines the whole car should be completely heat saturated,,, so don't start tuning on your engine till it's been running for at least 10 mins.. and always start on the rich side and work your way in slowly...
Joe Alessi
www.Lucky7RC.com
Old 10-06-2009, 07:46 PM   #21
wingracer's Avatar
Yes that's one thing, but not the only one.
1. At the time we didn't now this was a fairly new motor. The thing could have had 20 gallons of hard running on it for all we knew.
2. Lowsy fuel can do it.
3. Bad air filters in dusty conditions.
4. Defective finish on the crank pin (rare but possible).
5. Over revving or running a new super tight engine hard can egg out the bottom of the rod.
And a few other things I can't think of right now. Again I'm not saying you are wrong, just that there are other possibilities.
Team Shepherd USA
Old 10-06-2009, 07:59 PM   #22
jpalessi's Avatar
all very true...
Joe Alessi
www.Lucky7RC.com
Old 10-06-2009, 08:11 PM   #23
hyperc10's Avatar
Send a message via Yahoo to hyperc10
There are to many variables to decide what actually went wrong with this engine.I run Werks engines myself and can say the quality is unmatched.
hyperc10 is offline   Reply With Quote
