Old 10-06-2009, 03:37 PM   #1
Default HELP PLEASE.
Sorry about the lousy title Lol.
Ok. So what's happening is I just charged the starter box all night. It's at around 12.15 volts. Put the car on the starter box and It just seems to be burning rubber on the wheel. nothing else is happening just burning the wheel. And what's funny is that it was working fine just yesterday?
And the threaded wheel on the car just won't turn over.
BLink13 is offline   Reply With Quote
Old 10-06-2009, 03:41 PM   #2
blktransam's Avatar
Trader Rating: 59 (100%+)
sounds like your engine is stuck at Top Dead Center...or engine is seized/blown up? are you pre heating the engine?
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 10-06-2009, 03:43 PM   #3
It shouldn't have blown. I mean it was running fine just like 1hr ago. Stopped and put some new shock fluid in and it just wouldn't start again. And no to the pre heating
EDIT: to the things above, how can I see if it's blown?
Old 10-06-2009, 03:49 PM   #4
coviello's Avatar
your engine is stuck. take a screw driver and turn the flywheel
Barnstormers RC - Mugen Seiki - Hitec - EB Mods - Pro-line Racing - Lucky 7 RC
"Plug and play, Is not the way"
coviello is offline   Reply With Quote
Old 10-06-2009, 03:50 PM   #5
Yeah. I've been trying to. Just make sure I'm doing it right where is that located and what way should I turn?
Old 10-06-2009, 03:52 PM   #6
+1, or your starter box set up slipped, make sure the wheel is clearing the chassis opening.
triple7s is offline   Reply With Quote
Old 10-06-2009, 03:53 PM   #7
Yeah, this shouldn't be it. I've checked it like 5 times.
Old 10-06-2009, 03:55 PM   #8
blktransam's Avatar
as I said in my first post. engine is stuck at TDC, heat up the engine with a hair drywer or heat gun for 1-2 mins take a flat head screw driver and use the chassis as a "wedge" and turn the flywheel
-Ryan Klemme
Old 10-06-2009, 04:02 PM   #9
Integra's Avatar
On a side note.....12.15v on a gel cel is Way beyond dead...stick packs would also be dead if that's the way your using.
Old 10-06-2009, 04:03 PM   #10
madweazl's Avatar
Maybe I'm just lazy/ignorant but I never heat the engines. As stated, the piston is probably stuck in the pinch at TDC. You can manually rotate it (I used a pair of needle nose pliers on mine ) from TDC.
I need to shim the wheel in the starter on my box to bring it up a bit further; right now I have to push down on the plug ignitor to start it. If I push down on the back of the car the chassis flexes enough that I dont get enough pressure between the flywheel and starter motor. Is that something you could try?
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 10-06-2009, 04:16 PM   #11
Not sure.
Old 10-06-2009, 04:20 PM   #12
elkman's Avatar
Default Pull the exhaust off
Look in the cylinder and see whats happening when you try to rotate the flywheel. I would heat the engine for sure. How new is the engine anyway?
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 10-06-2009, 04:24 PM   #13
Oh well I jsut got it working LOL?
and sadly I have no idea how.
Well It's a very high end OS motor but It's pretty old and by that I mean it wasn't driven in awhile so this is the first couple of times I've gotten it up in awhile. THANKS THOUGHT GUYS!
Old 10-06-2009, 05:46 PM   #14
blktransam's Avatar
very high end o.s?...so a vspec?
-Ryan Klemme
Old 10-06-2009, 06:08 PM   #15
elkman's Avatar
Default Sounds like
A door stop now!
****RUSH****
Need help with engine please ( help please ) Chewwie Nitro Off-Road 15 08-28-2009 08:34 PM
Help please with stripped screws Wing Chun Electric On-Road 8 08-26-2006 02:50 PM
