Old 10-04-2009, 05:53 PM   #1
Default Sts .21 engine
Anyone ever any luck with these engines. I got one that likes to eat glowplugs. Just wanting some input on why it might be doing this. Thanks.
Twisted Nitro is offline   Reply With Quote
Old 10-04-2009, 06:01 PM   #2
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Originally Posted by Twisted Nitro View Post
Anyone ever ant luck with these engines. I got one that likes to eat glowplugs. Just wanting some input. Thanks.
mine is STS 21E model which look fine for me. The plug can last me atleast half gallon...I feel is your tuning problem....Try retune and see
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 10-04-2009, 06:05 PM   #3
The things is it will run fine and then next time I go to start it when I remove the glow starter it will dye everytime. If I put in a new plug it solves problem for a while.
Old 10-04-2009, 06:06 PM   #4
tkhoo's Avatar
Try increase the idle a little. Or warm up the engine and see it die or not....
Old 10-04-2009, 06:10 PM   #5
offr0aden's Avatar
I run a D21E - break in was tough as these motors are really tight. I run a JP-3 pipe on mine and really enjoying it. What model are you running, what are your needle settings, and are you running a turbo plug or standard plug (With the brass washer)? How many gallons, what temps, does it run fine and then die or blow the plug. I'm sure we can help, just need more information.
IMHO - these are great engines.
- Team -
"High Speed and Clean"
offr0aden is offline   Reply With Quote
Old 10-04-2009, 06:19 PM   #6
j_blaze14's Avatar
Trader Rating: 34 (100%+)
how do you shut down the motor?
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 10-04-2009, 06:20 PM   #7
wingracer's Avatar
Trader Rating: 23 (100%+)
One, they aren't the greatest motors in the world. Flame away all you STS fans but it's the truth.
Two, blowing plugs usually means too much compression or worn parts. If the motor used to be fine but just now started blowing plugs after a fair amount of use, it probably needs a rod and maybe bearings as well. If it's new and always done it, add a head shim or run less nitro.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 10-04-2009, 06:25 PM   #8
I run a turbo plug try to keep it around 200 to 215 and only has a gallon on it. It will run fine for a while and just blow the plug.
Old 10-04-2009, 06:37 PM   #9
offr0aden's Avatar
What is your head shimmed to? What nitro content are you running? That engine comes with a standard head button. So someone has changed it, and could have removed the shims. You should have 3 on there I have to check the thicknesses. It sounds like you have too much compression and or a stretched rod. First place, I would check is the head shims, take them off, clean them and mic them so you know how much clearance you have / or don't have
I'm shimmed for 30 but run Byrons 25 - good stuff and has plenty of power.
- Team -
Old 10-05-2009, 03:38 AM   #10
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
I am on my second d21e. the first one lasted 6 1/2 gallons without changing anything in it (bearings conrod etc). being a 3 port i generally run these at a warmer temp (225-250). break in isnt the most fun with these but once you get past the 1/2 gallon mark they run like a scalded ape and do so without tuning difficulty. plugs last about a gallon with me.
oh i bounce between 20% and 30% nitro juice depending on if it is for club racing or a larger event. these engines also like the 053 pipe
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
Old 10-05-2009, 06:22 AM   #11
My engine is the s21t model.
Old 10-05-2009, 01:39 PM   #12
I tried it after heating it with a heat gun and it does fine. Thanks for all the help.
Any Review on STS.21 buggy engine? jameslow Singapore R/C Racers 6 04-18-2009 10:05 PM
Sportwerks Mayhem Roller, Dynamite Starter Box w/ Batteries, STS .21 rcparts411 R/C Items: For Sale/Trade 11 02-01-2009 02:45 PM
