Old 10-03-2009, 04:16 PM   #1
clamber's Avatar
Default Oh crap, did I break it?
I just went out to get my idle problem fixed and my 8ight 2.0 RTR overheated after a few minutes so I turned the idle down and let it cool. Then I tried starting it later and it revved for a second and then died all of the sudden.
And so I pushed down on the ignitor again but I didnt get a response from the motor and the wheels started to turn. And I can spin the flywheel infinitely with my finger.
What happened? Did I break the engine?
clamber is offline   Reply With Quote
Old 10-03-2009, 04:18 PM   #2
coviello's Avatar
i think your flywheel nut came loose
Barnstormers RC - Mugen Seiki - Hitec - EB Mods - Pro-line Racing - Lucky 7 RC
"Plug and play, Is not the way"
coviello is offline   Reply With Quote
Old 10-03-2009, 04:20 PM   #3
clamber's Avatar
Where might that be? Sorry, Im new to nitro.
Old 10-03-2009, 04:43 PM   #4
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
behind the clutch bell. take it off and there will be a big nut in there.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 10-03-2009, 04:55 PM   #5
Cory Kerber's Avatar
http://www.youtube.com/watch?v=0C5Xz...layer_embedded
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 10-03-2009, 07:11 PM   #6
clamber's Avatar
Okay I got the engine off and the cooling head off as well. What do I do to get the rest off so I can tighten the nut?
Old 10-03-2009, 07:17 PM   #7
No need to remove the cooling head. You'll need to remove the clutch bell and then the clutch springs/shoes. You'll need a pick or tiny screwdriver to remove the clutch springs. Then remove the shoes and tighten the nut.
*TEAM TERRIBLES*
Old 10-03-2009, 07:52 PM   #8
Brad.R's Avatar
Trader Rating: 25 (100%+)
this happend to me when i got my 2.0, i would stop and take it to your lhs because you will need a special tool or you will break the crank like i did
Bad Brad Rutland
Memphis Missle
Ricky Retardo, (Don't lose that number)
Oops my bad, you were in my line..
You just got passed.. IN THE AIR!!
Brad.R is offline   Reply With Quote
Old 10-03-2009, 08:12 PM   #9
coviello's Avatar
you managed to break the crank?
Old 10-03-2009, 09:28 PM   #10
That vid is funny as hell! 20 years playing with nitro motors & never once has the flywheel just popped off from light taps like the vid says.They make flywheel removal tools for a reason,never ever hit the fltwheel with anything & dont pry with a screwdriver either,buy or borrow the correct tool.
If your flywheel nut came loose then you might not need the tool but use a new cone if it has, even if its a crapper steele cone instead of a brass one. Since you say your new the cones are not all the same so make sure you got the right one.
Why did you take the cooling head off? Just to see if the cyl is damaged?
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 10-03-2009, 09:44 PM   #11
Well like he said he's new to nitro...
Probably doesn't realise he didn't need to.
Cheers
anf0 is offline   Reply With Quote
Old 10-04-2009, 01:06 AM   #12
Trader Rating: 19 (100%+)
Hmmm... just thinking about it... if his fly wheel is spinning freely.. might be hard to get that clutch bell screw off :P
I'm thinking if he has the head off, he may be able to hold the piston at BDC with his thumb gently and then undo the clutch screw. Not sure if this would be a bad thing in anyway? I'm new to nitro too.
For the record clamber,
You need to;
- take the clutch bell off (that small gear thing that sits infront of the fly wheel). Generally you'd just wear gloves, hold the flywheel, and undo the screw on the end of the clutch bell, some people use tools to hold the flywheel but i've never needed to.
- You will see the nut in the middle of the clutch shoes, and if you cna get tools on the nut to tighten then do it, otherwise you'll have to take off the clutch shoes. To remove them it's a matter of flexing the springs on the clutch and just pulling it off the pin. I'd recommend you do it in a bag, and definitely wear safety glasses or something just in case the spring go flying :P
You can buy clutch tools for about 10 bucks which make removing and installing clutch shoes very easy... so you may want to invest in that, and possibly the flywheel puller too... although i agree if your flywheel is spinning then it'll prolly be easy to remove, so you probably won't need the flywheel puller on this occasion.
Again i'm new to this hobby too so i may be wrong, especially about the holding the piston down thign :P
LordAnubis is offline   Reply With Quote
Old 10-04-2009, 06:58 AM   #13
elkman's Avatar
Default WOW
somebody needs to make friends with a fast guy at his local track. You are in way over your head.
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 10-04-2009, 08:26 AM   #14
Danny B's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to Danny B
if you overheated the engine and there doesn't turn out to be anything wrong with the clutch...how about replace the glowplug...
Danny B is offline   Reply With Quote
Old 10-04-2009, 09:10 AM   #15
jrwoodchuck's Avatar
Damn Homer!!! Every single one of us started without knowing a thing! Cut the guy some slack and he will get things figured out.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
TAOB Racing! Bring it!!! charlie_b California Racing 9502 07-04-2016 12:35 AM
I want out. sokar Nitro Off-Road 80 07-10-2009 04:37 PM
===VERY nice M8 with two receivers...check it out=== WYLDTHING R/C Items: For Sale/Trade 36 05-27-2009 08:07 AM
break in engine frantic Singapore R/C Racers 64 07-29-2002 11:40 AM
