Old 10-04-2009, 01:23 PM   #16
WingWrecker's Avatar
My 350 did the same thing. Flywheel nut came loose. Scared the crap out of me though.
Then of course I couldnt get the clutch bell off because it was just turning the engine when I tried to unscrew it. I bought a 'piston stop' tool at my LHS. It screws in the head where the plug usually goes and stops the piston before TDC so that you can unscrew the clutch bell.
Once the clutch bell was off all I had to do was retighten the flywheel nut with my 4-way wrench and I was good to go. Didn't have to mess with the clutch shoes or anything.
8ight 2.0 RTR - 350 w/Turbo Head - Re11 - 4 Shoes - Ace servos - AKA tires
WingWrecker is offline   Reply With Quote
Old 10-05-2009, 08:29 AM   #17
elkman's Avatar
Default I am
Originally Posted by jrwoodchuck View Post
Damn Homer!!! Every single one of us started without knowing a thing! Cut the guy some slack and he will get things figured out.
I wasn't busting his balls, I was telling him that he needs to pair up with a fast guy and learn from him. Reading it on here only does so much.
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 10-05-2009, 12:31 PM   #18
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
Not sure if I understand the exact problem here. When you try and start it up, the wheels would spin? If that's the case, then I believe that you broke a spring in your clutch causing a shoe to hang on the clutch bell..basically, the bell is spinning with the flywheel causing the wheels to spin.
Did the engine just quit running when you tried to stop the wheels from moving ( full brake )?
If the flywheel nut was loose, then I can't see the tires turning when you try and start it..nothing should turn except the flywheel if it's loose. It sound like a clutch spring to me, causing a shoe to hang up.
If your engine isn't firing, it could be your plug or ignitor, and there's a possibility that you may also be flooded. Just a shot in the dark because it's hard to analyze engine problems without seeing and hearing it.
Someone suggested to buddy up with a fast guy at the track, I agree, nitro can be frustrating even when you're experienced. The fast guys are generally usually eager to help a new person if they have the time( and if they have any class at all )out because, because they know how nitro can be, and they also want them coming back to the track
GOOD LUCK!
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
TAOB Racing! Bring it!!! charlie_b California Racing 9502 07-04-2016 12:35 AM
I want out. sokar Nitro Off-Road 80 07-10-2009 04:37 PM
===VERY nice M8 with two receivers...check it out=== WYLDTHING R/C Items: For Sale/Trade 36 05-27-2009 08:07 AM
break in engine frantic Singapore R/C Racers 64 07-29-2002 11:40 AM
