Old 10-03-2009, 07:45 AM   #1
Suspended
Trader Rating: 1 (67%+)
Default will this work
will the motor out of a duratrax warhead fit into a mbx5
mach1rustler is offline   Reply With Quote
Old 10-03-2009, 07:54 AM   #2
Madbrad's Avatar
Trader Rating: 29 (100%+)
Im not to familiar with the waread, is it a pull start motor ? The Mbx5 requires a bump start motor, in most cases. I have not seen a pull start or roto start in a race buggy, but yes physicaly the motor mounts will line up and fine. THe only issue you will have is with the pull start or roto start.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 10-03-2009, 08:34 AM   #3
Suspended
Yes, originally this was a pull start motor. But I am going to put a back plate on it and bump start it. The only issue that I am having is that i have never dont nitro before this is my first. and I put the motor in the car to look at it. and well take a look at the picture and see if this looks like an issue. the crank shaft is very close to the gas tank ans im not sure if everything will line up right.
Old 10-03-2009, 08:51 AM   #4
Put the clutch bell on and see if overlaps the gears or not. If it's alright, only thing I would worry about is the chasis flex and the shaft hitting that gas tank. I'd think you'd be ok though, maybe one of the MBX drivers can chime in on how close theirs is.
NitroAmmo is offline   Reply With Quote
Old 10-03-2009, 09:04 AM   #5
Suspended
I put the clutchbell on it and the gears meshed but the motor could stand to be moved back 1/8 of an inch or so would it hurt to widen the chassis holes to move the motor back?
Old 10-03-2009, 10:23 AM   #6
What motor mounts are you using?The ones for the mbx or the warhead? It would be better if you could mod the motor mounts (drill new holes) versus modding the chassis itself. That way you can go back to stock later on if you wanted to.
RoyP is offline   Reply With Quote
Old 10-03-2009, 02:39 PM   #7
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
if it fits but its tight its just fine. I had about .020 of an inch between mine and it was ok all season. After i switched to a one pice mount the clearance was way better though.
awdcameolsx is offline   Reply With Quote
