Old 10-02-2009, 07:59 PM   #46
blktransam's Avatar
Trader Rating: 59 (100%+)
Chris said he thinks it was running too rich? as for the backplate issue I have no idea? maybe jim talked to monty and could shine some light on this?
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 10-02-2009, 09:18 PM   #47
houston's Avatar
Trader Rating: 91 (100%+)
Call me ryan , I wanna get something worked out with you and your engine. If nothing else I am sure there are a few good parts I can get out of it . And give you something for it or whatever. Still got my number ?
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-03-2009, 07:12 AM   #48
Houston, if you worked on Speeds I would send you mine. I can look at a failure and tell what caused it also ... to me that is the fun part. Most people look at it as removing and replacing parts ,but if you do not find the cause of the failure it will happen again.I've worked on Chainsaws, dirt bikes and jetskis all of my life while I am new to nitro I am discovering that physics plays some funny tricks at these high rpms.I might just buy a Novarossi and send it to you and see how well it can hold a tune. I am pretty sure that once one of these engines get a little play in the crank pin that is the point that ignition timing changes and you start chasing a tune. I feel that once you start chasing a tune you are headed for a failure very quickly.On a break in ...at what point should someone change the rod????
Joey Platinum is offline   Reply With Quote
Old 10-03-2009, 07:39 AM   #49
RCmayor's Avatar
Send a message via Yahoo to RCmayor
but on the "expensive" side of the coin all they had to do was send me a new mill and then they would be getting a thread talking about how top notch they are and would be getting my money for years to come as I would then buy another novarossi when its time...
So lets see, you glue the back plate on, try to get it off, muck up the case and want them to send you a brand new engine? Hmm, I wouldn't if I was them.
RCmayor is offline   Reply With Quote
Old 10-03-2009, 07:41 AM   #50
houston's Avatar
Rod slop needs to be monitored , if you preheat and do not overheat or overrev the engine a rod can last a long time . If you get your engine in the 300 degree + range then you should just for safety sake change your rod as they lose there tempering around those temps . Its ok if it was only for 1 lap or so but a whole heat , no buenos
Old 10-03-2009, 06:02 PM   #51
Zerodefect's Avatar
I think you'd be really happy with a Houson tuned N21b limited. It has good bottom and is dirt cheap. Mine wasn't Houston tuned and modded but my next will be. But my stocker is great on small tracks and for $150 there isn't much to cry about if I do smoke it.
I think I'm going to try to round the edges of the conrod some. I think this engine just has a square el loco cheapo rod. Maybe a little dremel work could help some....dumb idea??
There's a guy or two running modded 3 port motors and they are plenty competitive and get good fuel mileage. JP has a Modded N21b based motor now to.
Zerodefect is offline   Reply With Quote
Old 10-04-2009, 07:22 AM   #52
Davidka's Avatar
Trader Rating: 75 (100%+)
Not worth the risk to mess with the rod. You could easily weaken performing a mod you will probably never notice.
Old 10-04-2009, 07:38 AM   #53
Zerodefect's Avatar
Yeah, thats what I thought. Had some tuning issues for the first gallon but I'm getting close.
Seems like a good engine for the price, picking up a 9886 pipe for it. Going to try a hotter plug, Novarossi #4.
Running 20/12 trinity monster and am a little unimpressed with thier new blend (less grape flavor). Going to switch to Byrons 20/12.
Old 10-05-2009, 08:38 AM   #54
elkman's Avatar
Default Never look back!
I'm telling you, you really need to buy a Houston race tuned engine. Once you do you will never again think of buying any where else. His engines scream. My son took 4th in a ROAR region 11 truggy championship and he took 1st in a points series this year at out local track and I took second. Never ever at any time did we have engine problems and we always finished our heats and mains.
Buying a Houston race ready engine is the only way to go. You dont have to worry about the break-in and when you drop it in your car you will be ready to race in 10 minutes/ How much easier can it be?
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 10-05-2009, 12:23 PM   #55
Send a message via AIM to David Alberico Send a message via Yahoo to David Alberico
If it is one thing I have learned is you get what you pay for. I think the best engine on the market is the OS Speed, even though it is expensive, it is the best. Easy to tune and easy to tell if it isn't tuned.
I don't run for OS, and this is the only time I have said I run an os engine, when asked, I run an alberico special.
the other part.... take care of your engine too, just having the best engine or top of the line isn't just the key to flawless running...
Always, Always, Always warm your engine up before you start running it, and when you start, take a warmup lap that not so hard on the engine. I see so many racers that start up the buggy/truggy throw it on the track and just take off. That is so hard on an engine, and it is the path to flameouts, a weird running engine, and a short engine life.
Also, and during practice of all times if the worst, don't run your engine out of fuel, those last couple seconds your engine is running so lean without oil to keep things lubed up. If nothing else if the car starts to lean out, at least stop and let the engine ldle.
I got my speed used, and followed all the basics and took care of my engine and the compression hasn't changed, the tune hasn't changed all year......
But to get back on subject, you have to remember that fusion motorsport is only an importer which means they have already paid for the engines he is selling, in this sport, it is hard to warranty with so many variables. Many don't even warranty a bearing failure....it is the risk of racing.
Castle Creations, J-Concepts, WMD Products, Clints Creations
David Alberico is offline   Reply With Quote
Old 10-05-2009, 12:37 PM   #56
merdith6's Avatar
Default Jim is ok....Not great.
I bought a 367 plus 2 last year and it's been nothing but flame outs after the first 2 gallons. It ran strong at first and now it's just not finishing races. I lost a few and thought it was the humidity or the glowplug or anything but a bad engine. I wrote Jim H. and he made it seem like they were great engines. then I read all about the flame outs on the net and I am dissapointed. If there is a defect in one engine then sure sorry and no warranty just buy another it might be your fauly, but a whole line of engines and I'm wanting my money back. I have been racing Novarossi for years now and have never had a problem. I love the p5 and the bf engines, but are these new engines flaming out too much or what? I only see the problem with the 367 is the toro nero updated inside to fix this problem I see it's the same case as the 367, and is theplus 4 working good? Just curious. One bad engine after theyears is ok, but will the trend continue?
merdith6 is offline   Reply With Quote
Old 10-05-2009, 03:56 PM   #57
blktransam's Avatar
and this is why I am done with novarossi....I have had over a dozen people pm me with their novarossi issues. and that jim will not fix or even offer help to fix. I buy my items based on customer service so guess its not just me that thinks customer service goes a long ways
-Ryan Klemme
Old 10-05-2009, 04:27 PM   #58
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Sorry to hear that Ryan.......I love my Nova's......never have a problem outta' my plus4 and im nearing gallon 6 with no maintenance yet...Novas are $$$
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 10-05-2009, 05:25 PM   #59
blktransam's Avatar
Trev glad you are having good luck, wish I was haha. I always ran RB's with great luck -one of the same as novas currently running a C6 was in my buggy going into my truggy now for indoor and put my S3 in my buggy for indoor...engine will idle all day long,never flames out, I can pull 12 mins out of it no complaints what so ever on my c6. but when it is done I am done going to prb. switch to the new ninja(o.s) not because I want to but because novarossi will not get another penny from me unless this is made right which seems like its not going to be so its water under the bridge now.
-Ryan Klemme
Old 10-05-2009, 05:44 PM   #60
I have not heard of hardly any complaints from O.S. users.... usually their customers are happy. I had a dud and they made it good by sending a brand new engine ..it was a .28xz ...what a screamer OMG!!!!!
a main hobbies poor customer service? ruggydriver Chat Lounge 56 08-28-2012 05:54 PM
12 engines GIDDE Nitro On-Road 50 12-05-2005 01:36 PM
