Old 10-12-2009, 03:24 PM   #226
Default crankcases
Just chiming in on the tabs breaking off, awhile back I went through 3 OS crackcases, and 2 Nova's with a Losi 1.0, either a hireline crack, or broken tab, I found that chamfering the motor alittle more on the Losi quick change resolved the problem
akiyama77 is offline   Reply With Quote
Old 10-12-2009, 03:54 PM   #227
blktransam's Avatar
Trader Rating: 59 (100%+)
o.s hairline crack on bottom of case prb. due to a touch of rod slop which hit bottom of case...had this happen to a local last year.
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 10-12-2009, 04:16 PM   #228
It is obviously a QA problem on the honeycombed tabs.The other guys in my area with the same problems got the same treatment when they inquired about replacement.As far as the previous complaintants engine it looked to me like a piece of flashing caused the backplate to bind during assembly and the person putting it together used the backplate bolts to get it to join the rest of the way tightening one side too aggressivly and scarring the inside of the crankcase.Looking at the pictures this is pretty obvious and I'm suprized you engine guys couldn't diagnose this.I guess it just needed a fresh set of eyes.I can't believe you blamed it on th purchaser.If it would have been assembled properly it would have been easy to get apart and he wouldn't have had to get so aggressive to take the backplate off therefore scarring it with his pliers .Again , this is very obvious and an engine modder should have caught it in my opinion.
pete 26 is offline   Reply With Quote
Old 10-12-2009, 05:49 PM   #229
Did you miss the part where HE pulled the backplate off when new to seal the engine, then HE reassembled it? Not saying it's entirely his fault, but he was the last person to assemble the blackplate before having problems the next time he attempted to pull it apart a gallon later...
Since the backplate was apparently easily removed the first time when he applied sealant, I don't see how this could be a factory defect, as you appear to be implying...
Anyway, glad to hear Houston and Fusion hooked up the OP. Just goes to speak for the quality of this company and those who represent it, if you ask me.
-Howard
pur3evil is offline   Reply With Quote
Old 10-12-2009, 06:14 PM   #230
houston's Avatar
Trader Rating: 91 (100%+)
In case you didn't notice , the end user has taken the engine apart once , sealed it with a sealer and quite possibly did what you have said himself .
As I have said before , I have seen many many engines and inspect every engine that goes out of my engine room . In all the time I have been dealing with these engines I have never seen this so please .
Engine issues are really 99% user error.
Please stop bagging on quality products and let's get on with ourselves
Every single engine that I have seen with broken tabs have been 100% mounting issues
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-12-2009, 06:17 PM   #231
houston's Avatar
-Howard
Thanks howard
Old 10-12-2009, 06:40 PM   #232
Enlighten me...... what makes a Novarossi rod better than a Speed??????
Also why doesn't someone make a billet case????? it appears that all I have ever seen are cast. (Junk).I believe cracked or broken tabs are a combo of bad materials / cheap cast junk and improper alignment and tightening procedure.
Now how many of you Nova guys are happy with the prices on parts???I am just checking to see if you would still use Nova parts if they were the same price as speed or maybe even V-spec.Do not get me wrong i am going to get a Nova.... I just would like for someone to enlighten me as to why they are more expensive than a Speed or a V-spec????
Joey Platinum is offline   Reply With Quote
Old 10-12-2009, 06:47 PM   #233
Yes I did miss that part.I appologize.I was wrong. Wasn't aware he had pulled it off to seal it.I have never had an airleak on a NR engine.I saw the pics and due to having my panties in a wad over some previous posts I ran my mouth without reading the first post.Please except my appology for this.I should have stuck to my own problem insted of trying to solve someone elses...I can admit when I'm wrong............My tabs however should not have broken and the replacement parts are still extremely overpriced.....I also think Nova Rossi are the best engines you can get.I just got a couple that were improperly molded and have seen several others and was not satisfied with the response from the distributor. My computer is very old and will not allow me to download pics or I would gladly post them......When things are mass produced things like this can happen.I understand that.Fusions response is where my problem lies..I will not pay 230 bucks for a piston and sleeve.That in my opinion is gouging the customer.
Old 10-12-2009, 07:38 PM   #234
houston's Avatar
Thank you for understanding and correcting when you are wrong , highly commendable .
I would love to see pics of the items you are mentioning as I am sure jim would also .
I have had one out of round casting in a novarossi block , it was 5 years ago and it was a nova made crono rs5 that the sleeve insert area was out of round causing blowby from the exhaust to intake area pressurizing the crankcase when up to operating temp and shutting off the engine .
If you are willing to handle the situation properly with jim you will get top notch service , if you call and present attitude and negativity , well , we found out with this thread where that will get you . But even then the issue was remedied by jim .
Happy motorin',
Monty
Old 10-12-2009, 08:10 PM   #235
Kind of on a different tangent, but after reading through the thread about SIC, it sounds like a lot of people cracked / broke mounting tabs on engines of several different manufacturers, on several different vehicles. Maybe it depends on track conditions as well as how the engine's mounted? I have yet to break a case, but I was a bit worried about it at the Manufacturer's Cup last year. They had a huge jump, and the surface was like concrete (similar to the SIC track).
Pete - No worries!
-Howard
Old 10-12-2009, 08:26 PM   #236
Davidka's Avatar
Trader Rating: 75 (100%+)
I have noticed that every time someone breaks a mounting tab off an engine, it's with a one piece mount (often Mugen's). If you have a one piece mount that ran fine with one or more engines and another engine's mounting tab broke off, you can bet the rest of the car that the engine mount doesn't fit the engine. FWIW, Xray and others sell engine mounts in an OS size and a Novarossi size.
The thing that makes Novarossi parts better than OS parts is lifespan. 30% more cost, 100% more life. Ditto the part about the OS rod taking the crank with it.
Old 10-13-2009, 12:01 AM   #237
mblgjr's Avatar
Trader Rating: 86 (100%+)
Monty
Hilarious.
I had a 5K that was the same way.
And the reason you don't see billet blocks is because of MASS PRODUCTION. It's just not cost feasible to CNC that number of billet blocks for the masses. Would it be better? Probably. Worth the cost? Not really.
BP Racing dabbled with CNC/billet blocks, not sure if they still do them or not; Rich Reid would know prob.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 10-13-2009, 03:15 AM   #238
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
Pics?????? I thought I read every post on this thread! everybody keeps saying pics, where are they?
Mugen Seiki \\ Dialed RC \\ Tekin \\ SMC \\ AVID\\ AKA \\ Futaba
OfnaJoe is offline   Reply With Quote
Old 10-13-2009, 07:15 AM   #239
houston's Avatar
Are you talking about pics of the engine this thread was started on the premise of?
Old 10-13-2009, 07:18 AM   #240
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
sup Monty........hope all is well
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
a main hobbies poor customer service? ruggydriver Chat Lounge 56 08-28-2012 05:54 PM
12 engines GIDDE Nitro On-Road 50 12-05-2005 01:36 PM
