Old 10-01-2009, 05:26 PM   #1
Garet Jax's Avatar
Trader Rating: 91 (100%+)
Default Have I damaged my engine....
I have been trying to tune it (my first tune) and it seems to have lost a lot of its pinch. Where before I started today I wasn't able to turn the flywheel over completely using my hand, now it is very easy to do so.
Have I damaged it?
I am not a "Tech Master" nor even close. I simply have a lot of posts. If you want some sage advice, the only that I can give is don't listen to me.
Garet Jax is offline   Reply With Quote
Old 10-01-2009, 05:28 PM   #2
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
if there was a drastic change yea you probly did. did u follow the break-in precedure?
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 10-01-2009, 05:38 PM   #3
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
Is this a new engine or one you put together? How hot did it get? I ask this because recently I forgot to put the silver shim in my v-spec and ruined the rod in the progress. Does it kinda feel "sloppy" at the top? If so I am willing to bet that your rod just got sloppy witch is better then some things that could of happened.
awdcameolsx is offline   Reply With Quote
Old 10-01-2009, 05:42 PM   #4
houston's Avatar
Have I damaged it?
very hard to tell without a teardown but i would venture to say yes if it was a new engine
if its very easy to turn over by hand i would venture to guess its an OS engine
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-01-2009, 05:45 PM   #5
Jaz240's Avatar
Trader Rating: 52 (100%+)
Just because it lost its pinch does not mean it is shot. Metal pinch goes away on all engines and they last a very long time after that. Compression is what matters, not pinch. Did you have the glow plug out when you turned the flywheel? Its much easier to turn over with the plug out. Start your engine and run it, if it runs good with good power and idles good your fine
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 10-01-2009, 06:14 PM   #6
easyryder's Avatar
Did it get hot, real hot, did the filter ever fall off, is the head loose, glow plug loose? Check everything twice, you get it nailed down
XRAY XB9. Rubber tires with foam inside and super glue to keep them on. Cheap, but fast radio, high dollar servos, savox, mostly.
Cheap .21 engine. Modern starter box, finally!
easyryder is offline   Reply With Quote
Old 10-01-2009, 06:56 PM   #7
Easyryder do you have a scoot????? Cool name BTW.
Joey Platinum is offline   Reply With Quote
Old 10-01-2009, 07:27 PM   #8
Zerodefect's Avatar
Nice, smooth, low key Vspud bash. I give it an 8/10.
Zerodefect is offline   Reply With Quote
Old 10-01-2009, 07:59 PM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
Was it hot when it was easy to turn over?
Old 10-02-2009, 12:20 PM   #10
Garet Jax's Avatar
OK - Here is an update.
The pinch is definitely reduced over what is was yesterday before I started. even cold with the glow plug in, the pinch is almost non-existent.
I have taken apart the engine and the top of the piston looks to have some marks on it. If you look at the picture, there are 3 concentric circles around the top of the piston. The area in the picture is smooth around those circles where it is ridged everywhere else on the piston.
I have looked to replace just the piston head, but don't see anything but the connecting rod.
I am driving a Werks B7 Pro and wwould appreciate any help in finding a new piston head.
I felt the engine had been broken in sufficiently using heat cycling so I moved onto tuning it.
I started by adjusting the high speed needle and making it leaner until it was hitting a pretty good high end. I may have made it too lean causing the temps to rise.
I then continued by adjusting the low speed needle and the idle screw until it was pretty good at the low end.
While adjusting I was checking temps at the glow plug. The temp readings were never above 230. I have a feeling that this is where my mistake was/is. I believe the temps got too high and I wasn't reading them properly.
If my temps indeed got too high, would the culprit likely be a high speed needle that was too lean or would it likely be something else?
Thanks.
Old 10-02-2009, 12:59 PM   #11
houston's Avatar
just a fact zero , the big bore short stroke design of the vspec will run with VERY little compression .
in case you haven't noticed i don't do too much bashing
Old 10-02-2009, 02:34 PM   #12
hyperc10's Avatar
Send a message via Yahoo to hyperc10
I run werks engines and if you didn't over heat the engine then put it back togather put a tune on it and run the crap out of it!!!As long as you are blowing smoke out of the corners your good!
hyperc10 is offline   Reply With Quote
Old 10-02-2009, 08:50 PM   #13
j_blaze14's Avatar
Trader Rating: 34 (100%+)
Have I damaged it?
you are using vague terms, "lost a lot of pinch" and "very easy" to turn over by hand. was there a point where the plug burned out? was there always smoke from th pipe? were you driving up and down a street or on a track? tuning to th street and tuning to a track are totally different. the motor may "feel" bad but if it idles clean and has good power and speed and stays clean on the outside, i say its just finally broken in and the mechanical pinch is gone. if you hold the flywheel and hold the motor horizontal, how long does it stay up before the weight of the motor takes it past tdc? if its less than 10 seconds the piston or sleeve could have gotten scrathced/scuffed, usually due to dirty air filter, they can only hold so much.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 10-02-2009, 09:27 PM   #14
houston's Avatar
Thanks.
agree with blaze , the piston looks pretty scored like a plug filament had a party in the combustion chamber and then took it to the after hours party through the rest of the engine
Old 10-03-2009, 06:15 AM   #15
hyperc10's Avatar
If there is scoreing in the sleeve or on piston you could have sucked dirt or ran a too lean condition and scored the piston due to broken filament.If this is the case you need to replace front bearing, its cheap so change it just in case.when you have front bearing out check the lateral movement of rear bearing with crank in.If it seems sloppy or gritty when spinning change it also.
Then send it in to rayaracing for a resize.I use him and he does great work and fast turn around time.
Houstons Engine Service H.E.S. houston Offroad Nitro Engine Forum 8821 06-17-2017 12:29 PM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
removing damaged screws 32819toon Nitro On-Road 11 07-28-2007 04:51 AM
I need some tuning help Greenbox Nitro On-Road 14 10-10-2005 05:49 PM
