Old 09-30-2009, 07:14 PM   #1
rotarynut's Avatar
Trader Rating: 30 (100%+)
Default Losi clutch vs. Ofna
Hi guys,I'm new to the sport but not to wrenchturning. I'll be receiving my first buggy shortly (used matrix R2) w/ lots of upgrades,it currently has an OS RG.21 in it, I plan on dropping an LRP Z.28R spec3 in it (I won't be racing), the.21 has a Losi clutch in it, I was wondering if it will fit the LRP, are the collets the same size? Should I buy an Ofna clutch? Can anyone give a comparison between the two (maintenance & performance, ease to setup).I'll accept any tips and pointers that you may have. On the LRP what kind of glowplugs should I use? I'll be running 30%nitro either O'donnel or Byron's original gen2, thanks once again.
rotarynut is offline   Reply With Quote
Old 09-30-2009, 07:18 PM   #2
DPowers's Avatar
Trader Rating: 79 (100%+)
the losi flywheel should be fine and i would run a medium plug in the lrp 28.
DPowers is offline   Reply With Quote
Old 09-30-2009, 09:39 PM   #3
A losi clutch bell may not fit because the gear extends further out on the bell.
bigde2001 is offline   Reply With Quote
Old 09-30-2009, 09:46 PM   #4
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
I run a Losi 4 shoe clutch and you have to move your engine back about 5mm unless you are putting it in a losi 8. I had custom engine mounts made for my car to use it. The four shoe is the ticket though, Answer RC makes one that will fit your car.
If your Losi clutch is the older 3shoe type you wont have any issues.
Caster Racing USA Dirt Oval
Hyperdrive
Tekin
THD Custom R/C Products/Team Holy Rollers/Team Terribles
loopedout is offline   Reply With Quote
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
losi vs king headz engine mount jrwoodchuck Nitro Off-Road 12 04-15-2009 06:01 PM
