Old 09-30-2009, 06:04 PM   #1
hdcruzer's Avatar
Default Carb return Spring.
I have a question about not having this hooked up. I have an 8ight-t 2.0 RTR. local expert aand track owner, said its better to remove spring as it can cut into carb boot and cause tuning and air leak problems. What do guys think and do.
hdcruzer is offline   Reply With Quote
Old 09-30-2009, 06:17 PM   #2
Trader Rating: 47 (100%+)
You can re-bend the spring so it doesn't
drag on the carb boot too tight. Then again,
I would rather worry about keeping a eye on
the carb boot than worry about a blown engine
from losing radio signal.
rageworks is offline   Reply With Quote
Old 09-30-2009, 06:33 PM   #3
omarwashington's Avatar
some people use one of those tangle-free hair ties, they are kinda like small clear plastic bands. I use 3 or 4 at a time to make sure i have enough tension. I will never run an engine without one of these, I have learned my lesson as I've seen and experience servos or other things that have blown engines at WOT
RCCARS!
omarwashington is offline   Reply With Quote
Old 09-30-2009, 07:11 PM   #4
houston's Avatar
Trader Rating: 91 (100%+)
goodys ouchless hairbands
clear in color
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 09-30-2009, 07:23 PM   #5
Trader Rating: 36 (100%+)
http://www.amainhobbies.com/product_...e-Return-Bands
NitroOB4You is offline   Reply With Quote
Old 09-30-2009, 09:47 PM   #6
shanty140's Avatar
I run two of those rubber bands posted above. They work awesome you just have to be careful. After a bit they will become weak and snap. I replace mine with new ones every couple of races or you can try and remember to look at them everytime you turn the vehicle on.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Savöx SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 10-01-2009, 04:38 AM   #7
http://www.walmart.com/catalog/produ...ct_id=10319772
MBX-6
Caster MK2 / N21BF / P5XLT H.E.S.
casevac is offline   Reply With Quote
Old 10-01-2009, 07:39 AM   #8
clear in color
I use pink ones
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 10-01-2009, 08:16 AM   #9
houston's Avatar
i have seen those gmk ones and they are nothing more than rubber bands and they do not last !!! http://www.walmart.com/catalog/produ...ct_id=10319772
these are the ones , i have used them with great success as well as many other racers i know .
Old 10-06-2009, 09:33 AM   #10
Racecrafter's Avatar
Trader Rating: 25 (96%+)
GMK Supply "Carb -O's"
They are fuel proof and thick enough that they won't cut the carb boot.
http://www.trackstarrc.com/servlet/t...B-O%27S/Detail
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 10-06-2009, 10:50 AM   #11
I just 1 of the hair things.
Chris Reilly is offline   Reply With Quote
Old 10-06-2009, 10:51 AM   #12
madweazl's Avatar
I dont bother; the only time a spring/band is going to help is if the throttle linkage pops off. The springs/bands dont have enough tension to pull an unpowered servo back. If you do get enough tension to pull it back than it's decreasing the performance of the servo.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 10-06-2009, 11:04 AM   #13
RJNicholson's Avatar
Ummm... Yes they do actually. Most people use digital servos now, and they take no force at all to pull back if they lose power.
They aren't like older analog servos where this was a problem, and they didn't have enough tension to pull it back.
And lol on decreasing it's power. That is far off. Digital servo's with over 200oz of torque would never show lag because of these. Don't forget digital servos also have double the holding power of there torque, so a 200oz servo can hold a single position with over 400oz of torque.
I can thump my JR Throttle servo when its off and move it no problem. Your post Mad really only can apply to analog servos which no one really runs anymore.
*Team Terribles*
Rigs Listed Below
Losi 8IGHT 2.0 B/BCE Chassis/OS VZB *Sleeper*/RE11/JRHV Servos/KHZ
Losi 8IGHT 2.0 B/Werks B7 Pro/2013/Hitech HV Servos
Losi 8IGHT 2.0 E/Mamba Monster ESC/Xcelorin 2100kv or NEU Castle 2650kv *RIP-LIPO FIRE
RJNicholson is offline   Reply With Quote
Old 10-06-2009, 11:34 AM   #14
madweazl's Avatar
It applies to my Hitecs as the spring didnt move it at all with the power off hence my statement that the only servos it would work on would be ones that would take a performance hit from using it. Perhaps all the other digital servos in the world are different...
RadioPost
Old 10-06-2009, 11:56 AM   #15
Not sure why yours is different unless your spring is really weak.
I use JR HV Servos and mine have no problem with a throttle return spring. Even the Hitech HV's that I have seen have the same free flow movement when off and don't have any resistance when trying to move them by hand.
*Team Terribles*
Rigs Listed Below
install a throttle return spring Sylvain Nitro Off-Road 32 05-05-2012 11:32 AM
8ight 2.0 RTR - Throttle Linkage and return spring b1alan Nitro Off-Road 15 03-11-2011 04:33 PM
Throttle Return Spring Problem helgso Nitro Off-Road 17 08-10-2009 11:05 AM
Throttle return spring on 1/8 buggy RGraves Nitro Off-Road 40 03-27-2009 05:41 AM
