Old 10-06-2009, 03:13 PM   #16
Frank L's Avatar
Trader Rating: 148 (100%+)
Nother vote here for the GMK bands you will loose them before they break. Since using these return bands no run aways and no blown engines. A few weeks ago I saw a run away blow an engine. They could not get it shut down in time.4 months ago I had a run away with a brand new os speed engine. When I put the engine back in after checking the clutch bearings I hastily forgot to but the band back on and well I lost the throttle servo and my truck went full speed into a fence. Luckily the turn marshal got it shut down in time before my new mill blew but I check and re check for that silly cheap little band now.
Old 10-06-2009, 03:27 PM   #17
RCmayor's Avatar
Send a message via Yahoo to RCmayor
I would always run something. I prefer the Xtreme or Dynamite ones that are bent to go around the boot.
One race this summer I had a freak accident were the rear drive shaft fell off and it went out the flywheel hole and hung there. The next jump the drive shaft was jammed back up into the car and knocked the throttle arm off. Since the spring was mounted directly to the ball the car just coasted to a stop. No fail safe would have prevented a runaway there. The only savior to this is the brakes would have still worked. It would have been a fight between the brakes and clutch though, and maybe a little smoke.
RCmayor is offline   Reply With Quote
Old 10-06-2009, 06:13 PM   #18
mcsquish's Avatar
This is what I use. I learned my lesson by some how having the radio battery getting ejected.....
http://www.teamcracing.net/index_pro...9&imgid=401096
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 10-07-2009, 02:38 AM   #19
RCmayor's Avatar
http://www.dynamiterc.com/Products/D...ProdID=DYN6640
These are the ones I have been using.
Old 10-07-2009, 02:54 AM   #20
losi_racer's Avatar
Trader Rating: 25 (100%+)
DO NOT USE SPRINGS. They WILL cut into the carb boot.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
install a throttle return spring Sylvain Nitro Off-Road 32 05-05-2012 11:32 AM
8ight 2.0 RTR - Throttle Linkage and return spring b1alan Nitro Off-Road 15 03-11-2011 04:33 PM
Throttle Return Spring Problem helgso Nitro Off-Road 17 08-10-2009 11:05 AM
Throttle return spring on 1/8 buggy RGraves Nitro Off-Road 40 03-27-2009 05:41 AM
