Old 09-29-2009, 12:59 PM   #1
coviello's Avatar
Default engine tool
are there any good ones besides the grp because its discontinued. like around that price range? thanks
Barnstormers RC - Mugen Seiki - Hitec - EB Mods - Pro-line Racing - Lucky 7 RC
"Plug and play, Is not the way"
coviello is offline   Reply With Quote
Old 09-29-2009, 08:24 PM   #2
I asume you are talking about the bearing puller. Ofna makes a nice bearing puller.
bigde2001 is offline   Reply With Quote
Old 09-30-2009, 03:57 AM   #3
coviello's Avatar
http://www.losi.com/Products/Feature...rodId=LOSR0050
looking for the whole sysyem.
Old 09-30-2009, 06:18 AM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
That system works so well it's worth it's weight in gold. Mugen sells the exact same kit it's around 200 so a little more expensive but well worth it.
Old 09-30-2009, 07:36 AM   #5
Lonestar's Avatar
sleeve puller - use a zip-tie stuck in the exhaust port, turn the flywheel, voila
flywheel puller - available for $<20 on ebay
Magic motor bearing pulling trick - use your kitchen oven
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 09-30-2009, 09:52 AM   #6
Bigedmond's Avatar
Trader Rating: 18 (100%+)
hay, while your heating up you kitchen oven at the track. Can you cook me some lunch.
Losi/mugen/GRP tool is what you want.
Bigedmond is offline   Reply With Quote
Old 09-30-2009, 11:55 AM   #7
coviello's Avatar
i could only find the mugen one for the .12 or will it also work for .21? and i thought the grp one was discontinued. i cant find it anywhere
Old 09-30-2009, 01:31 PM   #8
houston's Avatar
Trader Rating: 91 (100%+)
I have replaced thousands of bearings (literally) with a heatgun . Engine block only needs to be about 300 or so to pop bearings out . Wiggle out with the end of the crank and have the new one ready to go installed on the crank , drop it in, tap it in lightly to seat and cool .
There are ways to goof it up is why I don't recommend doing it yourself unless you are experienced in doing so .
And no I am not just saying this so you send your engine to me cause I really don't make much on bearing exchanges
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 09-30-2009, 02:48 PM   #9
Frank L's Avatar
This is true but with the GRP tool it takes only 5 mins to remove and replace the bearings and they are perfect every time, no hot engine to hold and no hammering involved. The right took makes all the difference.
Old 09-30-2009, 04:32 PM   #10
Why the heck would anyone want to take the bearings out of their engine??? Wouldn't it make it run weird???LOL Just pokin some fun. I am sorry. I promise to behave ...for a little while. Are they worth Money$$$???
Joey Platinum is offline   Reply With Quote
Old 09-30-2009, 04:40 PM   #11
Frank L's Avatar
Cake toppings...
Old 09-30-2009, 04:40 PM   #12
Zerodefect's Avatar
No way I'm paying 300 for a bearing tool when a stove and a hot mit work better. Spray a little Axe body spray in the case and the bearings slide right in.
For 300 I could send every engine I touch for the next 3 years out to get modded, pinched, and re-bearinged!
Zerodefect is offline   Reply With Quote
Old 09-30-2009, 04:54 PM   #13
I could eat any cake any where any time bring it on...... oh wait I'm on a diet. As of today 70lbs in 10 weeks.
Old 09-30-2009, 05:14 PM   #14
houston's Avatar
no hammer involved in my process and is perfect every time
you must be careful with pullers/installers as they are hard on the races and can ding them or the balls if you tap the slide too hard and pretty much ruin your bearing . also have seen people gall the block where the bearings seat and gouge the aluminum rendering the block useless .
Old 09-30-2009, 05:39 PM   #15
Frank L's Avatar
Ok Ill have your piece
17 Piece Nitro Engine Tool Set surreal R/C Items: For Sale/Trade 40 10-29-2009 10:09 PM
GRP Engine Tool good????bad???? Toiffel Nitro Off-Road 24 08-01-2009 01:44 PM
Anyone try out GRP's Engine Tooling System yet? magbarn Nitro Off-Road 17 07-05-2009 01:06 PM
GRP Engine Tool Frank L Nitro Off-Road 6 04-28-2009 09:01 AM
