Old 09-29-2009, 07:35 AM   #1
Default Confused...Futaba 3PK with Spektrum and Ofna failsafe?
Hey guys, I have the Futaba 3PK with Spektrum. I have been searching on here for a definitive answer, but can't figure it out. I know Spektrum has a built in failsafe (or so I have read). Can this be used with my 3PK in PPM mode? And should I use an Ofna failsafe along with the Spektrum Failsafe? Please only answer if you are completely positive and have experience with the above, as I would hate for my car to end up in a lake or wall. lol
Ryno RC is offline   Reply With Quote
Old 09-29-2009, 08:04 AM   #2
houston's Avatar
Trader Rating: 91 (100%+)
yes i am positive that spektrum equipment has a built in fail-safe and yes i am positive it works . no need for the ofna fail safe unit . to check where your endpoints are set after you bind , turn your radio off and see where the servos stay . some people like there car to go in circles if it loses signal so the wheels will be set one way or the other almost full lock . usually the throttle is set at neutral or a tiny bit of brake applied .
good luck and happy motorin',
monty
i run the futaba 3pk w/spektrum transmitter module and micro receivers
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 09-29-2009, 12:30 PM   #3
The spektrum system has a failsafe that you set when you setup the bind the receiver. As far as using the additional fail safe, you shouldn't if you are using the Spektrum system. When using the spektrum system with the 3PK, you should be using PPM unless you have the HRS version, either way, you shouldn't use the failsafe with the Spektrum systems.
Check you instructions or go to spektrums website to check how to bind and program your failsafe points.
I also have been using a 3PK and the spektrum system since it first came out.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 09-29-2009, 01:22 PM   #4
Thanks a lot for the very useful info guys. I will remove the Ofna Failsafe...couldn't stand it anyway cause the wire was like 2 ft long and I try to keep my receiver box looking clean. lol I'll have another look at the Spektrum manual.
