Old 09-28-2009, 11:08 AM   #1
Scott Kerkes's Avatar
Trader Rating: 83 (99%+)
Default Extreme racing carbon towers Good or Bad?
I run these on a D8 and every time they break in the same spot the top of the tower where the shock hole is drilled.
If you have an opinion based off experience with Extreme Racing towers please share.
Special Thanks to Axial Racing, Hobbico, TrakPower, Futaba and my local tracks OC/RC and Westcoast Raceway.
Scott Kerkes is offline   Reply With Quote
Old 09-28-2009, 11:15 AM   #2
wallot's Avatar
got only experience with WB-Racer-Ace towers that are 5mm thick and made much better(compared to just 4mm extreme racing) and even they break.
get aluminum towers (wb-racer-ace alu towers are very tough)
or even HB standard towers as aluminum will just bend allowing you to finish the race unlike carbon that will break and your run is over.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 09-28-2009, 11:21 AM   #3
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
the extreme towers are very good.. I ran them on my 5t with no issues..
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 09-28-2009, 11:25 AM   #4
san.'s Avatar
Trader Rating: 59 (100%+)
Are you using Coned Washers when mounting the shock standoffs? This will reinforce the setup.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 09-28-2009, 02:07 PM   #5
JPierson's Avatar
use a washer where they have ben breaking this will help spread the
stress load on the tower is it
the rear that keeps breaking?
HB D8 & D8t GRP .21 & O'DONNELL SS.21
JR 8711 & 9100s & Hitec 7955TG
M11 2.4 FHSS-2 •TEAM*TERRIBLES•
"I know I can't drive!! You still ACT like you can!!"
JPierson is offline   Reply With Quote
Old 09-28-2009, 03:20 PM   #6
Yes its the rear tower. The front will get stress cracks in a horizontal line at the top of the diff. case before breaking.
I am sure the washer helps but after 3 breaking I am going back to Aluminum.
Old 09-28-2009, 03:47 PM   #7
sickpuppy1's Avatar
Trader Rating: 25 (100%+)
I use Carbon fibers in many areas but shock towers is not one of them.....
Stickin way up there is an issue. Maybe OK on a 1/10 scale cause they are SO much lighter. 1/8 scalers are twice the weight and faster, It's gonna happen no matter who's Carbon it is.
If you cant fix it with a hammer, you have an electrical problem...
TeknoSCT410,Losi 22 2.0 & Eight-B 2.0,Losi LST2 , losi LXT circa 1990, it's a runner!
sickpuppy1 is offline   Reply With Quote
Old 09-28-2009, 04:17 PM   #8
Team Tekin
yzracer758's Avatar
Trader Rating: 17 (100%+)
I've ran the extreme carbon towers on my D8-E's front and rear and have been quite pleased with them. The only issue I have ever had with one was my rear tower broke where the rear turnbuckle mounts to the tower. A washer will help not put so much pressure on it and most likely saved it!
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics | Carolina Custom Anodizing
Jeremy Potter
Tekin C.S. Manager
yzracer758 is offline   Reply With Quote
Old 09-28-2009, 05:37 PM   #9
Integra's Avatar
IMO Extreme tower's are low grade SSG composite like most other Upgrade tower's you can buy.....RC mfg's cant justify the price of REAL Cf its Way too expensive.
Old 09-28-2009, 05:41 PM   #10
san.'s Avatar
Here's a pic of the Coned Washers I use:
Old 09-28-2009, 05:53 PM   #11
Integra's Avatar
Gotta love Boeing Grade CF.
Old 09-28-2009, 07:44 PM   #12
stoney1974's Avatar
Trader Rating: 11 (92%+)
i run them towers on my rc8 no problems but i was always told to put ca tire glue around the edges and over all the holes on any carbon tower
drive fast take chances
www.askrcracing.webs.com
crazy traction compound
stoney1974 is offline   Reply With Quote
