Old 09-28-2009, 09:50 AM   #1
Default Air Bubbles
When building the shocks, im having problems with air bubbles. I have the assembly built, the piston is at the very bottom, filled it up slowly with oil about half way, push the piston up and down slowly to remove bubbles, top off the assembly with oil, then slowly worked the piston up and down once again to remove the excess bubbles.
Im not sure how slow to work the piston, or maybe the process in working out the bubbles is wrong, but the oil contains a lot of small micro bubbles. Thinking that maybe these small bubbles wouldn't be a problem and out of curiosity, I finished the build by installing the little rubber stopper, capped it, pushed the piston to the very top, loosened the cap halfway, then retightened (which I take is to bleed the remaining air)... and once done, I can feel air as I work the shaft.
After work I am going to drain the entire thing, try to pour more slowly (not pouring slow enough maybe??), move the piston more slowly to see if that helps. As this is the first shock build for myself, any ideas would be great... or even a good tutorial (i am searching now myself).
saki2fifty is offline   Reply With Quote
Old 09-28-2009, 09:56 AM   #2
losi_racer's Avatar
Trader Rating: 25 (100%+)
do you let the shock sit a little before putting that cap on?
i put fluid in it(i just squeeze the bottle i never cared about speed) and once it to the top i work the piston up and down slowly put spinning the shock shaft at the same time idk if this helps but ive always done it. Then set the shock aside, do the remaining 3 and by the time youve down 3 the first one should be pretty air free. some people make stands for shocks to sit, i used to use stacked tires. you just want the stock stright up and down with the cap off
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 09-28-2009, 10:08 AM   #3
Echelon's Avatar
http://www.youtube.com/watch?v=rixBJu93Qyw
http://www.youtube.com/watch?v=H8gJUGXceso&feature=fvw
Echelon is offline   Reply With Quote
Old 09-28-2009, 10:46 AM   #4
madweazl's Avatar
I typically fill the body about 1/2 full, run the piston close to the top of the oil level and go back down (very slowly; typically the slower you go the bigger the bubbles are). Top it off, run it back and down again. I usually dont need to repeat it again. If I do get the annoying little bubbles I flick the side of the shock body a bit (not sure it helps get them to the top faster or not but it makes me feel better ).
Obviously dont fill them all the way or they will hydraulic and be tougher to bleed.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 09-28-2009, 11:00 AM   #5
Amoeba's Avatar
Send a message via AIM to Amoeba Send a message via MSN to Amoeba Send a message via Yahoo to Amoeba
If you're not letting it sit or the microbubbles aren't floating out use physics. Hold the shock body by the top and whip it around in big windmill circles like a centrifuge. The centrifugal force will push the heavier oil down and force the lighter air bubbles out.
Erin Carroll
Do Not Taunt Happy-Fun Ball
Amoeba is offline   Reply With Quote
Old 09-28-2009, 02:01 PM   #6
shanty140's Avatar
You have to watch when letting the air out under the piston. If you continue to go up and down with the piston after the air bubble releases you will get tons of little bubbles and will take forever for them to float up and go away. I usually let them sit for like 1/2 hour. I build them exactly like in the nitro house video link. It has worked well for me so far.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Air Bubbles in Shocks? Chris__RC Nitro Off-Road 10 01-23-2009 05:00 PM
air leak? ruggydriver Nitro Off-Road 7 10-18-2008 12:19 AM
air bubbles in the fuel line hobdog Nitro Off-Road 19 08-28-2008 04:34 PM
$10.00 Shock - Air Bubble Remover...! tbeardmore Electric On-Road 13 04-15-2008 10:42 AM
ride air remover RP600 stephen hilton Electric On-Road 22 04-08-2008 03:06 PM
air bubbles in fuel line jackhammer74 Monster Trucks 6 07-01-2005 10:08 AM
