Old 09-28-2009, 07:21 AM   #1
Default Lipo issues with HV servos?
Befuddled – I am running 2 Hitec HV servos (the high torque ones), Losi 2000mah Lipo and Spektrum radio. Now when I was running the JR servos on a regulator, I can run all day 3 – 7min quals and a 20 main with no problems.
Now once I switched to the HV servos, After a full charge (or what my charger say is full) it just died on me in 15 min in the main. When I got home I checked the voltage of the lipo receiver pack and it read 1.7v and 1.9 volts. Now I have never seen this pack under 4v
So I guess my question is, Will the HV servos at 7.4v drain the receiver pack faster that regulated at 6v? I really don’t understand the characteristics of LIPOs and the output ect.
Yes I charged it before the main and sure of it.
I tested the off and on switch and it works.
I charged another lipo with the charger and it was fully charged.
Could it be the receiver? It was BRAND NEW.
Im at a loss- any help or ideas would be appreciated
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 09-28-2009, 07:30 AM   #2
PTP Racing's Avatar
I dont know the answers to your questions but my first thought is your lipo battery is dying.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 09-28-2009, 07:35 AM   #3
Frank L's Avatar
Trader Rating: 148 (100%+)
I started running hv servos and lipo packs at the same time about 3 races ago. I noticed that with a new lipo pack the first 2 times it seemed to drain fast, but now after 3 or 4 charges the packs took about 650mah after 15 mins of practice and a 30 min main. The 1st time withthat sam situation the same pack took 1300mah so they seem to be broke in now. I run the exact same setup in the buggy and truggy and they behave the same.
Are you balancing your pack? And it sounds like the pack is done as 2.6v per Cel is the minimum that a pack can have and still be good. I would try a new battery and give it a couple of cycles before you mak a decision. I would say a lipo pack should be able to do 90 min no prob on hv servos.
Old 09-28-2009, 07:43 AM   #4
Lonestar's Avatar
"I'll tell you this bud", let me crawl back in my hole now
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 09-28-2009, 08:24 AM   #5
Paul
Old 09-28-2009, 08:40 AM   #6
madweazl's Avatar
I have the same setup and didnt have any issues. I havent balanced the Losi pack yet (my charger had the wrong adapter and so did the balance plug I bought ).
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 09-28-2009, 10:33 AM   #7
hummmmmmm, i think I have a bad pack........ thanks guys
Old 09-28-2009, 01:53 PM   #8
shanty140's Avatar
When the HV first came out a racer at our track had the same problem you had. He phoned Losi up and they said at the moment they don't have a pack that will last the amount of time. I couldn't believe when I heard that found it pretty hard to believe that they would come out with servo's that they can't even run for an A-main. Now I don't know if the Losi guy was covering his ass on a defected product that they didn't want to replace, or was actually telling the truth. If people are able to run them with the same setup as you I guess you have your answer.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, SavŲx SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 09-28-2009, 02:12 PM   #9
RJNicholson's Avatar
I run the JR HV servos and the DX3R on the Losi 2S Lipo.
I can run about 1hr to 1:30 mins on my packs with no issues. I can tell when they are losing their punch though, but they still run great.
I bet your Lipo is gone just from the fact that you said your below 3.2v p/cell. Do a discharge test on it with your Charger.
The Losi Lipo is 2000mah. Lipo should never drop below 3.2v p/cell.
That being said on a full charge (4.2v p/cell) you should be able to discharge the Lipo to the cutoff voltage (3.2v p/cell) and have drained if not all very close to 2000mah. That's the best way to check the Lipo, and make sure you are getting the maximum usage out of it. Anything dropping below 3.2v is dangerous for the cell and it will become unstable. You have to charge the battery at 0.1a until you reach 3.2v p/cell, or you can risk blowing the pack. That's why they are not suppose to drop below 3.2v.
Hope this helps. I just took the Lipo101 class from my LHS electric guru.
*Team Terribles*
Rigs Listed Below
Losi 8IGHT 2.0 B/BCE Chassis/OS VZB *Sleeper*/RE11/JRHV Servos/KHZ
Losi 8IGHT 2.0 B/Werks B7 Pro/2013/Hitech HV Servos
Losi 8IGHT 2.0 E/Mamba Monster ESC/Xcelorin 2100kv or NEU Castle 2650kv *RIP-LIPO FIRE
RJNicholson is offline   Reply With Quote
Old 09-28-2009, 02:22 PM   #10
Frank L's Avatar
Ya I think you have a bad lipo pack. The servos are good.
Old 09-28-2009, 02:36 PM   #11
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Originally Posted by token View Post
So I guess my question is, Will the HV servos at 7.4v drain the receiver pack faster that regulated at 6v? I really donít understand the characteristics of LIPOs and the output ect.
yes..
IMO the HV servos are overkill but it's nice to get rid of the regulator.. After dumping that pack i would pick up some new ones and just re-peak them during the day..
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 09-28-2009, 04:05 PM   #12
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
If this is a Losi 2000 7.4v lipo pack, it should have a low voltage cutoff. I know, since it refused to show any power one time after we shut the car off. Once a charge was placed back on it, it came back up. Pretty odd to run the lipo down to 1.7v-1.9v. Its usually toasted and will die off with no voltage reading at all.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 09-28-2009, 04:26 PM   #13
Cory Kerber's Avatar
I don't know if this matters, but he's talking about the Hitec HV servos. Everyone else is talking about the JR HVs.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 09-28-2009, 05:34 PM   #14
Integra's Avatar
X2 on the NOT going below 3.2 ...i also took some lipo 101 classes from a Flyboy who uses big dual 10S in heli's...he also told me a few other lipo tid bits that have come in handy over the last couple years.
Old 09-29-2009, 09:16 AM   #15
OK guys, thanks for all the feedback. after checking and re checking - its the of-on switch
Baddest servo on the block PERIOD. Integra Radio and Electronics 345 03-25-2012 06:37 PM
Recommend Servos Banter Radio and Electronics 63 09-05-2010 06:34 PM
ACE 1015 on unregulated lipo? WingWrecker Nitro Off-Road 35 09-21-2009 12:40 PM
LiPo and servos Amoeba Nitro Off-Road 17 08-19-2009 10:29 PM
Best servos on the market Obsidian Electric Off-Road 15 02-04-2009 08:10 PM
