Old 09-27-2009, 06:22 PM   #1
easyryder's Avatar
Default SH .21 project= Frankenstein
Alright I have been racing Sh Engines for 5 years strait, I have torn down, checked out, rebuilt many variations, Going to toss in a stock 350 Losi 3 port piston and sleeve into an AB modded top of the line pt2008pt, with dynomite 9 port crank, non puddy version and see what happens Will it run??
Lets see!!
XRAY XB9. Rubber tires with foam inside and super glue to keep them on. Cheap, but fast radio, high dollar servos, savox, mostly.
Cheap .21 engine. Modern starter box, finally!
easyryder is offline   Reply With Quote
Old 09-27-2009, 07:39 PM   #2
Madbrad's Avatar
Trader Rating: 29 (100%+)
I have always been curious as to what would happen if you were to swap parts like that. I think it will run but probably not the best performance.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 09-27-2009, 08:41 PM   #3
fast11970's Avatar
Lemme know LiL Bro!
MBX6
http://www.racemugen.com
fast11970 is offline   Reply With Quote
Old 09-27-2009, 08:44 PM   #4
I believe it will work.
bigde2001 is offline   Reply With Quote
Old 09-27-2009, 08:47 PM   #5
rossoh10's Avatar
Budget racing at its best.......Go for it Easy..Give us reports
TEAM WTF
RC10B5m
rossoh10 is offline   Reply With Quote
Old 09-27-2009, 08:51 PM   #6
fast11970's Avatar
Why not the balanced crank? Whats the logic there?
MBX6
Old 09-27-2009, 08:54 PM   #7
fast11970's Avatar
Perhaps Adam B. Can Chime in here? What ya think?
I for one think it will be a monster, Just hard to keep on a leash..
MBX6
Old 09-27-2009, 10:03 PM   #8
mblgjr's Avatar
Trader Rating: 86 (100%+)
Any chance you could take a pic of the discharge/counterweight end of the crankshaft exit?
Just wanted to compare it to the Losi 350.
Thanks!
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 09-28-2009, 12:04 AM   #9
FUEL FLAMES's Avatar
I think it's going to blow up on the ground and bruise your big toe
Dave Salas
FUEL FLAMES is offline   Reply With Quote
Old 09-28-2009, 03:39 AM   #10
It will work just fine . And will run great!
BeefHead is offline   Reply With Quote
Old 09-28-2009, 06:23 AM   #11
easyryder's Avatar
This crank is from the ab mods, puddy was peeling just a little so left it out. The dischange is exact same thihg only bigger. I forgot to mention the
dynamite crank is the putty version.
Ready to drop in, start break-in process tonight and race it on Wensday night, Hopfullly
Hey Dave my toe is amost all healed up Maybe I am a wuss?
Old 09-28-2009, 05:03 PM   #12
easyryder's Avatar
It runs!!
Two tanks on the starter box at 200 degrees, sounds ready to battle already, off to the park for ground test, mo break-in at least 6 more tanks before wensdays race!
Old 09-28-2009, 05:30 PM   #13
fast11970's Avatar
So how did the power feel?
MBX6
Old 09-28-2009, 06:50 PM   #14
easyryder's Avatar
6 tanks wasted, it is ready and has plenty of power, will be racing it on wensday and if it is right will take it to the pit for the summer series final It has big bottom, purrs like key, key
Old 09-28-2009, 06:53 PM   #15
easyryder's Avatar
MEOW.
