Old 09-27-2009, 08:00 AM   #1
Angry rc10gt stalling please help!
hi i have an rc10gt witha o.s max .12cv-r. i will start it up and while idleing for 30secs it starts to idle slower then the tires start spining faster and faster as the idles get slower and slower till it stalls i have played with the high and low end as well as the idle and th.trim please help i was going to track today but not now.
HAGGARTY is offline   Reply With Quote
Old 09-27-2009, 08:11 AM   #2
Me thinks one of two things. Air leaks or clutch.
The Working Man is offline   Reply With Quote
Old 09-27-2009, 08:13 AM   #3
ok do you have any idea where it could be leaking and whats up with my clutch to tight or lose?
Old 09-27-2009, 08:16 AM   #4
coviello's Avatar
your clutch is way too loose. whats happening is your springs are worn out so when your just sitting there idiling your shoes are opening so its grabbing the clutch.
Barnstormers RC - Mugen Seiki - Hitec - EB Mods - Pro-line Racing - Lucky 7 RC
"Plug and play, Is not the way"
coviello is offline   Reply With Quote
Old 09-27-2009, 08:22 AM   #5
to tighten the clutch is it the large black gear like the nut and spring? is that what causes it to stall? the idle raises and lowers at random aswell
Old 09-27-2009, 09:33 AM   #6
sounds like an air leak on the carb somewhere, or maybe your exhaust gasket even. if the exhaust gasket is bad or loose it would cause this too. and as far as tightening the clutch, you just need to buy new springs. when you remove your clutch bell be careful not to lose the two shims on the clutch bell screw, the pop off the springs and get some new ones. maybe even get some new clutch shoes while your at it. good luck and let us know if you get it fixed.
iraqsucks is offline   Reply With Quote
Old 09-27-2009, 12:28 PM   #7
i just check my exhaust and there is no gasket at all the pipe is bolted straight to the engine ....wow i bought this car a week ago used so i guess there might be other problems i dont know about
Tags
rc10gt help
