Old 09-26-2009, 08:33 PM   #1
Cory Kerber's Avatar
Default Diff Cup Bearing Removal
I'm rebuilding my xb8 replacing all the bearings. However, i can't figure out how to remove the bearings on the diff cups. I didn't see any type of set screw in the cup, and the other side is a diff gear. Can these bearings be replaced?
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 09-26-2009, 08:37 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
the diff itself?
it has to be disassembled
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 09-26-2009, 08:42 PM   #3
Yes, the diff itself. I'll dissemble it again and see if i totally overlooked something.
*TEAM TERRIBLES*
Old 09-26-2009, 08:45 PM   #4
imaxx21's Avatar
the diff cups have to be removed too...
pull the little flat sun gear off of the inside of the big ring gear and pull that pin out
-Crash
Old 09-26-2009, 08:49 PM   #5
rcjunky10's Avatar
Trader Rating: 217 (100%+)
Default TTT
Cory, you will need to completely disassemble the diff, which means taking out the spider gears which will expose the large sun gear sitting on the bottom of the diff. cup. Under the Sun gear is a pin which passes through your outdrive securing it in place. Once you remove that pin the outdrive will drop out of the diff cup and voila you can now remove the bearing. Repeat this process on the other Sun gear. Obvisously there are no Spider gears on the Crown gear side of the diff so removal is a bit easier.
You will most likely need to clean out the diff cup as the Sun gear gets stuck on the on the outdrive. The fluid forms a vaccuum so get yourself a pair of need nose pliers and gently work it lose. Also, cleaning the diff of all residual fluid will aid in breaking this suction. Good luck and just ask if you have any additional questions!
rcjunky10 is offline   Reply With Quote
Old 09-26-2009, 09:20 PM   #6
Thanks for the replies, i got it all figured out with your help! My diff bearings thank you!
*TEAM TERRIBLES*
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
