Old 09-26-2009, 01:57 PM   #1
Default Help with losing signal.
Hello. I have an airtronics m8 and when im running my car there are a short couple of seconds where i lose control with my car. Then seconds later I have it back. I am using the spektrum pro module for the radio. The battery level on the radio is at 10.0 volts. Any ideas?
teh835 is offline   Reply With Quote
Old 09-26-2009, 07:28 PM   #2
Sounds like a module problem. If you know any one with another module try theirs and see if it works.
bigde2001 is offline   Reply With Quote
Old 09-27-2009, 02:17 AM   #3
I had the same shit happen with my Spektrum DX3.0 this weekend. Exactly as you describe, just randomly every now and then losing control, sometimes constant. Changed the receiver, still had the same thing happen.
We raced in VERY high and strong winds this weekend though and that's the only thing different to last weekend when it was working fine...
Cheers
anf0 is offline   Reply With Quote
Old 09-27-2009, 02:38 AM   #4
mrbusta's Avatar
Trader Rating: 20 (100%+)
Send a message via MSN to mrbusta Send a message via Skype™ to mrbusta
Default help
personally this aint a shit session but i find that so many have the spektrum that there has to be glitch issues
i found many using the spektrum style have these issues
personally the m8 is a great radio and it works a treat
i have the m11x so far so good and it works on the fhss3 band new and improved and faster as the write ups
now i did have a issue at the nats wich i had the same issue as u and what i did find is that the servo plug had come a tad loose unoticable by a glance until further inspec the other thing could be is dirt in the receiver
as its u anfo ill try help wen i can as u have done in the past for me on the other hope this helps
SHAYNE/MONSTER ENERGY/BETA TYRES Australia
Thanks to www.wprcracing.com/P.N.D Paint works
81/MUGEN Mafia
RIP BUSTA BB ANGEL
mrbusta is offline   Reply With Quote
Old 09-27-2009, 09:40 AM   #5
its because spektrum sucks. get the airtronics DSSS 2.4 system and say goodbye to glitches, runaways, loss of signal and any other problems
quicklosi is offline   Reply With Quote
Old 09-27-2009, 03:28 PM   #6
offroad racer's Avatar
I had a problem with my spektrum dx3s this weekend but turned out to be a bad reciever battery connection
Losi 8ight-T 2.0
Losi 8ight 2.0
TLR 22
Ofna Nitro DM1
offroad racer is offline   Reply With Quote
Old 09-27-2009, 03:43 PM   #7
Cory Kerber's Avatar
I've had this problem also with my m11 with Spektrum module. Turned out to be a bad receiver pack.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 09-27-2009, 04:30 PM   #8
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
I had the same issue but I'm using a spektrum radio (dx3r). Changed battery, reciever, switch and still had the problem. Apparently, model 1 was the issue. Soon as I bound the reciever to another model on the radio the problem was fixed. I know ur running only the spektrum module and not their radio, but give that a try if u've already gone through everything else.
KIK is offline   Reply With Quote
Old 09-27-2009, 04:39 PM   #9
Taylorm's Avatar
....had an issue with my M11 and Spektrum also..my Serpent would work correctly on the starter box....as soon as the car was on the track the vibrations caused the connection on my receiver pack to go "open" momentarily......checked battery and one of the factord spot "welds" was broken.....changed battery....problem gone....start with the simple stuff first.............battery..........
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Spektrum allrc Radio and Electronics 2545 07-17-2012 08:25 AM
New Novak Brusless System danjoy25 Electric On-Road 2688 10-14-2010 08:40 AM
2.4GHz interference with brushless??? HELP! JSR Electric Off-Road 25 09-13-2009 10:18 AM
3PK - Spektrum System Charles_Howarth Radio and Electronics 274 11-03-2007 08:28 PM
