Old 09-25-2009, 10:25 AM   #1
forty6and2's Avatar
Trader Rating: 107 (100%+)
Default v-spec p/s and bearing question
anyone got a line on a good place to get some ceramic bearings for the
v-spec vzb for a reasonable price.. hard to justify that 2 ceramic bearings are worth 60.00...wth?
also looking for a reasonable price for a new piston and sleeve.. 90 bucks on egay a bad price? piston sleeve and con rod?
forty6and2 is offline   Reply With Quote
Old 09-25-2009, 10:42 AM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
60 bucks for ceramic bearings is steep. I paid 36 for front and rear at carolinasrc.com. Here are the part numbers
TKOCBMR25414 - TKO Ceramic Rear Engine Bearing 14x25.4x6 V-Spec RB Nova *@ *$22.99
TKOcb607C2rs - TKO Ceramic 7x19x6 Front Engine Bearing (RB, OS, Nova) *@ *$14.99
those are going in an os speed engine which takes the same bearing as the reg vspec. Also check out their p/s/r you may be pleasantly suprised. 90 does not sound bad. I paid more than that for the speed versions. Hope that helps.
Old 09-25-2009, 10:48 AM   #3
forty6and2's Avatar
nice.. that helps alot. thanks
Old 09-25-2009, 12:09 PM   #4
RJNicholson's Avatar
Just put both of those bearings in my VZB along with the speed rod and crank.
Couldn't be more impressed with the bearings and the service from TKO.
My VZB is a completly different beast, and it will help me keep my Speed in my bag for when I really need it!!
Top notch in my book. All my engine bearings from here on out will def be TKO Ceramics.
*Team Terribles*
Rigs Listed Below
Losi 8IGHT 2.0 B/BCE Chassis/OS VZB *Sleeper*/RE11/JRHV Servos/KHZ
Losi 8IGHT 2.0 B/Werks B7 Pro/2013/Hitech HV Servos
Losi 8IGHT 2.0 E/Mamba Monster ESC/Xcelorin 2100kv or NEU Castle 2650kv *RIP-LIPO FIRE
RJNicholson is offline   Reply With Quote
Old 09-25-2009, 12:20 PM   #5
forty6and2's Avatar
tkos are ordered and on thier way
Old 09-25-2009, 12:31 PM   #6
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Just popped these guys into my v-spec the other day as well. Feel nice, good price. Can't wait to get everything back together.
BTW, you sure you need a new P/S? Maybe just need a repinch?
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 09-25-2009, 01:47 PM   #7
22Racer's Avatar
Trader Rating: 67 (100%+)
If the piston and sleeve are just worn from normal use I can resize it for only $15.00. It will run better as good as new and it can be done 3-4 times on the same motor.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 09-25-2009, 02:23 PM   #8
forty6and2's Avatar
so are you able to tell if it needs a pinch or its shot by pics?
heres the deal:
i bought it off this forum being told it had 2 gallons on it, ive put about 8 tanks of 20% on it, also doing some research 2 gallons is not alot for an os motor.
it was running fine until 2 days ago. not it wont stay running and its spitting fuel out of the carb when im on the throttle. the piston i can push in the sleeve pretty easy and go as far as in the pic and pull it out just the same,but i cant push it all the way through.
i can turn the crank over very easily with 2 fingers. .i posted this on another forum and guy said that it looked like some of the chrome was worn off.. whats your thoughts.
Old 09-25-2009, 02:41 PM   #9
kuruption's Avatar
You may be fine with a repinch and replacing your rod, like I did. I don't think your stuff looks much worse than mine did, certainly has more time on it than my 4 gallons.
Check out the pictures at http://www.rayaracing.com/image.htm. He shows a before and after of his work.
If you can push the piston through the sleeve towards the top, then you could use a repinch. You see where the black stops inside the sleeve? That's where it would normally stop.
At the least, I would send your stuff to either RayA or similar and have them look to see if it's salvageable and can use a pinch. If not, you're only out $15-20. If they are, then you saved yourself $100.
Ray Sundland
Old 09-25-2009, 02:48 PM   #10
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
better pics of the piston (exhaust side) and head button please.. also is that as far as you can push the piston in the sleeve? don't use force! also u should check the case for cracks along the bottom before you do anything..
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 09-25-2009, 03:23 PM   #11
forty6and2's Avatar
i can push the piston about 1/8th past where it normally stops when running.. there are zero cracks in the case
here ya go
Old 09-25-2009, 04:35 PM   #12
Frank L's Avatar
I don't see any vertical scarring on the piston it looks ok to me, I have never had a sleeve pinched either. I usually get rid of the engine at the 7 gal mark or drop in a new p/s/r and bearings and then go another 7 gallons.
Old 09-25-2009, 04:36 PM   #13
22Racer's Avatar
If you can push the piston beyond where it normally runs it needs a pinch. The biggest problem with that motor is the crank wears a little sonner than most, at 2 gallons it should be fine. Check how much slop there is with the new rod.
Rex
Old 09-25-2009, 06:08 PM   #14
jpalessi's Avatar
everything looks usable, the button looks slightly pitted but it's all good... what fuel do you run? I would consider switching... if you have a caliber mic the crank pin and see whats up,, if it's anymore then 4 thousands out of round then it's a problem..
Joe Alessi
www.Lucky7RC.com
Old 09-25-2009, 10:52 PM   #15
forty6and2's Avatar
i run blue thunder race 20%, ive only ran about 8 tanks through it. and those 8 tanks everything was fine. good tune, idled forever, nice top and bottom. then 2 days ago it starter running a bit funny like it was loading up and doing some "run on". so i tuned it a bit but could not change anything. took the motor apart, inspected it ,put a new plug in, cleaned the carb out(suspecting some dirt) its all clean as a whistle,, now i need to hold the throttle open about 1/4 trigger to get it to idle, i pulled the air filter off to see how big the idle gap was and it was open about double what it should be and normal when i let go of the trigger then it dies. the carb was also spitting out fuel while the filter was off,like lots. like spits it 2 feet away.. which im thinkin is not normal
so here i am, a motor that wont tune or run and in pieces , waiting for me to decide what to do
O.S Engines thread TTR:EB4 Offroad Nitro Engine Forum 2421 Yesterday 08:42 AM
