how to change a conrod
anybody have any vids on how to do it? Bout to change the rod on my ninja. Advice? never done it before.
what kind of tool do i need to get the clips off? I have some old pistons to practice on.
There's a guide on RB's website...
http://www.rbproducts.com/mainEn.php...ncept%20engine
You're actually not supposed to re-use the clips. Oh ya, make sure to wear some eye protection. I had one go flying into my eye the other day.
Yep I second the eye protection. Luckily I blinked!
Nah, I've been re-using the g-clips for so long without any problems. Get a pair of tweezers to make things easier. Cheers
i am like one of the fastest guys to work on a motor,
i blew a con rod in my grenade (i know i know shut up)
and i pulled it apart put a new con rod on it and got it running while the truggy 5min qual was going and i had it ready in time to run a worm up but it was short lived as i stalled because i left a 2mm chunk of alum in the bearing.
Take the Wrist pin clips off IN A zip loc bag....you'll thank us later.
As stated move the piston to near top dead center and remove the back plate.
Rotate the piston to BDC and remove the sleeve.
Take a sharpie and put a dot on the rod just above the crank pin as well as the exhaust side of the top of the piston. (You will appreciate this later)
Once again rotate the crank to TDC (or there abouts) and slide the rod off of the crank pin and remove the assembly out the top.
Also as stated put the assembly in a clear plastic baggy to remove the clips and to re install them.
Notate the rounded portion of the crank pin bushing as this will go against the crank fillet. (Check reference against the one that was removed) assemble the same way it came out again checking your dot on the piston for exhaust side reference.
Reassemble in reverse as stated above.
Any questions feel free to PM or email
Jimmy Wright
Track Star Racer Services
[email protected]
