Old 09-22-2009, 05:06 PM   #1
alexrckid's Avatar
Default engine runs hot after a few minutes of racing..??
can anyone explain to my why a perfectly sealed engine(including the entire fuel system/tank) would temp and run fine for the first few minutes of a qualifier/race and then have the temps climb up into the low/mid 300 range ?? the engine(v-spec's) got about 9 tanks thru it....backplate, carb and h/s needle are all sealed. the front bearing is not leaking. plenty of engine smoke upon acceleration.....but, i've been told that if the L/S needle is set a bit too lean that it could cause an engine to overheat the longer that it is run.....typically after a few minutes of hard running.....anyone ever heard of such a thing..??
alexrckid is offline   Reply With Quote
Old 09-22-2009, 05:11 PM   #2
DPowers's Avatar
Trader Rating: 79 (100%+)
are you trying to tune the motor before it gets up to temp.
DPowers is offline   Reply With Quote
Old 09-22-2009, 05:23 PM   #3
wingracer's Avatar
Trader Rating: 23 (100%+)
Sometimes if the top is right but the bottom is too lean the temps will just keep climbing.
Also, it can take well over 5 minutes of running before the motor reaches full temp so if it's a bit too lean it might not show on the temps during warm-up.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 09-22-2009, 05:25 PM   #4
alexrckid's Avatar
do all the tuning after running 2-3 minutes after the engine temps in the low/mid 200's...............just chasing the L/S deal............the engine passes a 3-5 second pinch test after a few high speed passes......
Old 09-22-2009, 05:26 PM   #5
alexrckid's Avatar
thanks for the input guys...........you've given some good advise.......
Old 09-22-2009, 05:29 PM   #6
DPowers's Avatar
if you have anymore just ask and good luck.
Old 09-22-2009, 05:35 PM   #7
Zerodefect's Avatar
Plenty of smoke?
When I'm lost I tune till I'm a bit boggy (rich) and retune. make sure your hot before you tune like said above.
I like to stop for 3-5 seconds on the turn after the straight. (The low needle pinch test never works for me. ) It should bog just a little when you take off again if its too rich on the bottom. And I make sure I've got good smoke at least half way down the front straight.
Spit test, well don't spit on the head, i usually wipe a bead cross the top of my Novas head, it should boil and bubble for a bit then maybe evap in a few more seconds (250?). If it dissappers too quick then you really are too hot.
Usually my wet finger deosn't get burnt, but it should hurt. Pain is hardly a good temp gauge though.
Zerodefect is offline   Reply With Quote
Old 09-22-2009, 05:47 PM   #8
wingracer's Avatar
Oh yeah, one other thing. Not all tanks react the same. Most tanks will run a bit rich when full and lean out as it goes down. This can cause the motor to heat up at the end of a run. Some tanks stay pretty consistent through a run, some actually do the opposite. Start out lean and richen up. Weird I know but anyone that had an original tank Mugen MRX3 knows what I mean.
Team Shepherd USA
Old 09-22-2009, 06:40 PM   #9
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
Before I tweak any of the needles, I run the car/truck until the chassis is very warm to the touch under the center diff and engine area.
The ONLY exception is if I know it is WAY off.
If I am not sure how warm the engine is and if it hasn't radiated enough heat yet, ie:get the warm up late, etc. I will try and stay a little on the rich side, meaning that the car won't feel as crisp, knowing it will improve in a couple minutes.
This of course means you won't be stretching the fuel mileage to 9 or t10 minutes, but it also means more time between rebuilds!
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 09-22-2009, 07:07 PM   #10
reggie l.'s Avatar
did you mess with the mid-range alex?
make sure you tune evenly...like just cause it runs ok, dont mean your hsn couldnt be causeing you random flame outs or over heating on the track,same goes for the lowend...adam drake talks about it really well in that nova-rossi tuning vid on youtube..
what carb insert you running? i wouldnt go over a 8mm
how is the idle?
what pipe do you run
_ClockWork-Racing_
http://www.clockworkracingengines.com/
~8t 2.0
~MUGGIFIED Lst-xxl
reggie l. is offline   Reply With Quote
Old 09-22-2009, 07:37 PM   #11
alexrckid's Avatar
didnt touch the mid range spray bar. and, when it does "overheat" it comes into pit lane actually "humming" rather than idleing......hot, for sure.
Old 09-22-2009, 07:46 PM   #12
wingracer's Avatar
Big indication of too lean on the bottom.
Team Shepherd USA
Old 09-22-2009, 08:23 PM   #13
reggie l.'s Avatar
i agree...
mabe back it out some on the bottom and lean it out on the top some to compensate...of kourse depending on the situation etc..
_ClockWork-Racing_
~8t 2.0
~MUGGIFIED Lst-xxl
Old 09-23-2009, 10:13 AM   #14
alexrckid's Avatar
i did find out that whn came in "humming", richening up the lo-speed was a fix............just cant figure out why..??
Old 09-23-2009, 10:17 AM   #15
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Chances are Brad that you have a false idle, and it's making it imposable to get the LSN right.. Come see me next weekend and i'll get it straightening out for you..
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
RB Concept Engine Thread.. r1harper Offroad Nitro Engine Forum 3632 06-14-2017 12:29 AM
Nitro Engine Break In d4_racer Australian Racing 50 02-22-2011 02:42 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
What is the best way to break in a new ening? adsl Onroad Nitro Engine Zone 27 02-10-2005 07:49 AM
