LOSI BOX STARTER PROBLEMS
I HAVE A LOSI 2.0 BUGGY AND TRUGGY AND HAVE HAD NOTHING BUT PROBLEMS WITH MY LOSI BOX STARTER. I HAVE IT ON A LIPO AND CAN'T KEEP BELTS, MOTORS OR WHEELS ON IT. I KEEP OVER HEATING THE MOTORS AND BATTERY. I PRE HEAT ALL MY MOTORS AND STILL OVER HEAT IT ALL.
PLEASE HELP ME..................
WHAT MOTORS DID YOU GO WITH AND DOES YOUR LIPO GET REAL HOT?
I havent had any issues with mine really. I discovered quickly that I couldnt pop it on the box and press the rear end down or the flywheel would slip on the starter wheel. Once I pushed down on the plug ignitor or heat sink it made good contact and I didnt have any problems. I'm going to shim the entire assembly "up" a little bit to alleviate this issue.
I dont preheat my motor and run two cheap stick packs. It will last at least 2 complete race weekends (to include practice runs).
is it the black box, throw in 2 ofna 770 motors and you will be good
i went with two traxxas 12-turn titans for my race 2.0 truggy.......work great.
If they are the same ofna motors in the truggy box, which I believe are 775, just redrilling the holes will not work. The center opening is not large enough to tighten the belt. In addition the ofna motors have a different size pinion which screws up the whole belt size. Like I said, I am referring to the truggy box 775 motors.
ya....i just used some new losi belt drive gears(pressed on)...but, the mounting screw holes line up with the traxxas motors.........just have to carefully space the motors so that the flux rings dont contact the (metal) box, itself..........over time, with contact the motors magnets will weaken, slightly.....
