Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-20-2009, 05:28 PM   #1
Default V-Spec Pro Mod vs. Mugen JX21 EBMod
I broke the crank pin off of my 10 gallon Go Tech so I'm shopping for a new motor. I'm between the V-Spec Pro Mod and the EB Modded JX21. It's going in a RC8T truggy.
I like that the EB mod comes with the head button and it's broken in...I'd probably end up getting the EB head button for the v-spec anyway so it would probably end up costing more in the end.
So - the big question - which one?
HiVoltg12 is offline   Reply With Quote
Old 09-20-2009, 06:14 PM   #2
Trader Rating: 23 (100%+)
go with the ninja, you will have more then enough power and really good fuel mileage, i get 11 min run times on mine with the eb button, the promod v spec is similar to a speed but with a blue head, it wont hit as hard on the bottom like the jx
dialed inc/ebmods.com/answer-rcusa.com/m2c racing
rc8b ebmod ninja jx
mbx6t ninja jx/eb head button
cjm1126 is online now   Reply With Quote
Old 09-20-2009, 08:20 PM   #3
Trader Rating: 18 (100%+)
even though i have 2 OS speed motors, my vote goes to Ninja. ran against it. see it run.. IMO better motor,
Odonnell Z01B-Z01T | Odonnell SS21 | OS Speed | Tekin RX8 | Hitec | Zippy | Odonnell 20%
Support your LHS, Al's Hobby, Elmhurst
devilchrist is offline   Reply With Quote
Old 09-21-2009, 12:57 AM   #4
I run speeds, and have to say that I'd go with the JX Ninja. After you get the motor, if you want a little more power you can always add the speed crank to make it even more of a screamer. The only thing I'd do with the stock JX is after break in, I'd change out the bearings to TKO's if possible.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 09-22-2009, 07:42 AM   #5
So the JX21 will have more bottom and be overall smoother than the V-Spec?
I am planning on running the AE 2035 pipe for a short bit...I'll get a 2050 or 2060 later on down the road.
Old 09-22-2009, 08:04 AM   #6
token's Avatar
I have to disagree - the Vspech is a smoother Engine period - the ninja has more bottom, but my modded Vspec is faster reving and reaches top speed faster.......... my ninja is great for tracks that has jumps right out the corner, but high speed tracks with smaller jumps - I use my vspec
Losi 8T 2.0 - OS Engines - Spektrum DX3R - Hitec HV- Byrons Fuel - AKA - Team Terribles
token is offline   Reply With Quote
Old 09-22-2009, 08:14 AM   #7
j8ight13's Avatar
hey man, i just picked up the promod and ninja a few days ago. For the truggy, go with the ninja man. I put the ninja in my losi 8ight-t2.0, and the promod in the 8ight-b 2.0. I love these mills. They screammmmm. ESP the ninja!! Its just a bit over the promod. the promod could deff keep up with the ninja but is a lil smoother than the ninja IMO.
Good luck with whichever you decide man. They are both great!
Team Losi/8ight 2.0-8ight-T 2.0 Hot Bodies/D8
Nova +4/ GRP MRT .21/GRP .21/GRP MRT .28/Ninja JX21/OS V-spec PROMOD
Hitec 7954HV,7955/ JR 9100s-t/ JR 8800s-t
GRP 2053, RE10, RE11, NOVA9901
DX3S/M11x
j8ight13 is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.6
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
