Old 09-19-2009, 06:56 PM   #1
karrar55's Avatar
Default T maxx 2.5 body fitment
does the t maxx 3.3 body also fit on the t maxx 4910 2.5?
karrar55 is offline   Reply With Quote
Old 09-20-2009, 04:35 PM   #2
Stubbs's Avatar
Trader Rating: 57 (100%+)
It depends. If you have the shorter chassis 3.3 (model # 4909) yes, it will fit. If you have the newer, extended wheelbase 3.3 (model # 4908) no, the body will be about 50mm too long.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 09-20-2009, 05:31 PM   #3
karrar55's Avatar
i have a t maxx 2.5 4910, im tryn to see if a tmaxx 3.3 body would fit a 2.5 tmaxx
Old 09-20-2009, 06:27 PM   #4
Stubbs's Avatar
Yep, the 3.3 body will fit just fine. Just make sure you get the 4909 version. The only difference will be that you'll have more room around the cylinder head with the 3.3 body, when running it on a 2.5.
I've got several 3.3 "basher bodies" that I use for pratice out at the track. They look like 12 kinds of crap, but I don't care if they get beat up...saves my good body from taking all the damage.
Old 09-20-2009, 07:06 PM   #5
karrar55's Avatar
a seller on ebay said that the 4908 body wont fit a tmaxx 2.5.
Old 09-20-2009, 07:24 PM   #6
Stubbs's Avatar
That's correct. Like I said in my first post, the 4908 is the newer, extended wheelbase 3.3. The older, shorter chassis is the 4909. That's the one you want for a 2.5.
Old 09-20-2009, 07:56 PM   #7
karrar55's Avatar
o sorry i thought u said 4908 my bad
Old 09-21-2009, 04:49 AM   #8
Stubbs's Avatar
It's all good....Traxxas is a bit frustrating because they use a lower model # for the new vehicles. I think it makes more sense to start with the low #, and increase it for the newer models, but that's just my 2 cents.
