Old 09-19-2009, 01:36 PM   #1
tristyn's Avatar
Default Team Orion ajustable volt. regulator
I have been running lipo rec. bat. for a couple yrs. now. My problem is I run the futaba FASST 2.4 SYS. and when ever I race where it is hot aprox. 85 deg. and up my receiver shuts down and goes to failsafe usually after about 10 min. of running. I believe this problem is do to having the regulator in the rec. box and getting to hot. I have used 3 to 4 different brands of regulators and still have the same problem. When I mount them on the outside of the rec. box I don't seem to have this problem but the regs. do not last very long for me on the outside. I was recently browsing through Amain and noticed a new regulator out made by Team Orion. This reg. seems to have a hard shell case which looks durable and sealed up from contaminates and it is ajustable from 5.5v-7.0v 10amps. Has anyone had any experience with this
Thanks for any info.
tristyn is offline   Reply With Quote
Old 09-19-2009, 03:11 PM   #2
Zerodefect's Avatar
I haven't used the Orion ones but there are regulators geared towards airplanes that are worth looking into as well. Usually they have dual output/inputs for 2 batteries and Rx's.
20 amps with a hard al case/heatsink. I've seen them at hobbytown before.
PM the Joey Platinum, he used to run one.
Zerodefect is offline   Reply With Quote
Old 09-19-2009, 04:35 PM   #3
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
I got one and it's GREAT, It's mounted on the top of my battery box on my MBX6 and is about 1 inch from the header and have never had a problem with it, even during 30 min mains.Mine is set at 6.4v and works awesome
Mugen Seiki \\ Dialed RC \\ Tekin \\ SMC \\ AVID\\ AKA \\ Futaba
OfnaJoe is offline   Reply With Quote
Old 09-19-2009, 05:17 PM   #4
2fst2c's Avatar
Trader Rating: 114 (100%+)
I run them also. I have them all mounted outside and have never had a problem with them. I have had the fasst receivers shutdown from heat though even with the regulator outside.
2fst2c is offline   Reply With Quote
Old 09-27-2009, 06:32 PM   #5
counterman's Avatar
I've been running it for 2 races now and I have mine inside the receiver box and I have a mini receiver squeezed into the switch box on my MP9 and I haven't had any issues and I've been known to practice for and hour straight.
HPI/Hot Bodies, Team Orion, VP fuels, Pro-line, OS Engines, Futaba, Full Throttle R/C Raceway www.ftrcr.com
counterman is offline   Reply With Quote
Old 09-27-2009, 06:35 PM   #6
Trader Rating: 94 (100%+)
Send a message via Yahoo to captaindemo17
Check this out..
http://www.teammarketingamerica.com/...directory.html
captaindemo17 is offline   Reply With Quote
