Old 09-18-2009, 10:41 AM   #1
Default rc8t setup help?
hey guys i have a setup question on my truggy about the diffs, it's a stock rc8t rtr, i took it to a state race last weekend, and i noticed that the front end pushes when trying to corner, that's on or off the gas, i was running aka city blocks soft all around, and the rearend is to loose, i run on a clay sand mix track, that is pretty smooth with some blue groove, i run 7,7,7, diff oil all around, i'm just not very good at setting up the diffs so the truck will drive better, what would be a good diff oil setup to run in my truggy, i just need more traction i guess?
trents88r is offline   Reply With Quote
Old 09-18-2009, 10:57 AM   #2
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
I run an XRay XT8 Truggy and it was suffering from the same symptoms you describe. Felt like a dump truck in corners for sure! I popped my diffs out, cleaned them up good...and went with 7 - 10 - 5 for fluids and it is NIGHT and DAY for me. The Truggy is now completely flickable in corners and reacts VERY VERY fast compared to what it used to. The fluid change alone made me a good 15-20 seconds faster per lap by allowing me to put the Truggy where *I* wanted it to go...and not where it felt like it wanted to go.
I wanted to run 3 in the rear, but I had none on hand...so I chose 5 and it's been working great thus far. Someone recommended 10-15-3 to me as a nice setup and that would probably work very very well too. My new fluids just get more power to the front wheels which makes cornering effortless now. The old fluid was 5K and beat to death so the front just wasn't digging in...no matter what tires I ran.
My experience is little at the moment though, only 6 months in the hobby...but learning fast. After this fluid change....I will be checking/changing it every 3-4 races max....
MotoGod is offline   Reply With Quote
Old 09-18-2009, 11:16 AM   #3
jzemaxx's Avatar
On my RC8T-E I ran 7-10-3. Ran awesome with that setup.
Kyosho MP9 TKi2 Tekin
Kyosho MP9 TKi2/3 Novarossi BTT
jzemaxx is offline   Reply With Quote
Old 09-18-2009, 11:21 AM   #4
STUBYSLAP31's Avatar
Trader Rating: 27 (97%+)
ok, ive been dealing with this all year, i finally got it straight 7-10-5, the key with ae is ride hieght, 38mm front 44 rear, garunteed, a couple local factory ae guys fixed me up, whole new truck
hope this helps
STUBYSLAP31 is offline   Reply With Quote
Old 09-18-2009, 11:25 AM   #5
BIG RE's Avatar
Trader Rating: 32 (100%+)
I do not run a RC8T myself, but I helped my buddy set his up and I believe we settled on 7-10-2.
BIG RE is offline   Reply With Quote
Old 09-18-2009, 11:26 AM   #6
I run the 7-7-7 on my RC8T. The only time the truck pushes is on throttle or if I get back on the throttle in the center of the corner. I have tried the 7-10-5 setup and didn't notice much difference. I run a heavy rear bias on the brake and throw the truck into the corner. When there is alot of traction this can be an issue as I rely on the rear to slide. I was thinking of trying the 7-10-5 (did not notice alot of difference with this setup) again the next time out, or even the 7-10-3. I did notice that moving the battery up front has helped a bit.
Tekno NB48 Samurai Proline Tires
Tekno NT48 XZB Speed Proline Tires
Tekno EB48.3 Viper Proline Tires
Tekno / Dialed RC Hobbies / TKO Competition Development /
Stirex is offline   Reply With Quote
Old 09-18-2009, 12:19 PM   #7
Default 7-7-3
I had the best luck with 7-7-3 in the diffs. 38 ft. 44 rear ride height with the assocaited ride height guage with the battery mounted up front. I had the pushing problems and this is what fixed it for me. Tons of steering now.
8T 2.0's, 8TE 2.0, 8 2.0, Tekno 8 2.0E, Ten-SCTE's, 22, Tekno RC8.2E's, RC8E, RC8TE, B44, Tekno RC8TE, MBX6T, Tekno MBX6TE, Tekno EB 48.
aaronmn is offline   Reply With Quote
Old 09-18-2009, 12:25 PM   #8
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
Team Associated 1/8 scale Truggy Info and Tips
This night help ya
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 09-18-2009, 01:41 PM   #9
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Diff 7-7-7
shocks 1.3mm x 6 pistons 45f 40r all AE fluids
-2 camber front and rear, 2+ toe front, 3- toe rear
Short hubs front, long hubs rear
38mm front ride height, 44mm rear
battery forward
14t clutch bell, 50 spur
stock AE clutch shoes, with 1.0 springs
I also have a little more rear brake bias. probably 65r35f
Bigedmond is offline   Reply With Quote
Old 09-19-2009, 09:40 AM   #10
thanks alot guys, this was tons of help, my ride height is all messed up then it's like 32mm all around, never messed with it
Old 09-19-2009, 12:37 PM   #11
flippz's Avatar
Default ride height
whats the best way to adjust the ride height?
RC8T-Werks B5-M11 Airtronics-B4.1
flippz is offline   Reply With Quote
Old 09-19-2009, 01:03 PM   #12
MotoGod's Avatar
Adjust your shocks for ride height. Either via spacers...or by tightening/loosening the preload adjuster.
rc8t ruggydriver Nitro Off-Road 110 10-13-2014 11:12 PM
need help choosing a truggy ibmenace Nitro Off-Road 66 09-12-2010 02:00 AM
*#* FT Associated RC8T-E ROLLER FS/FT*#* losi 8t R/C Items: For Sale/Trade 28 09-18-2009 06:45 AM
RC8T steering??? trap121 Electric Off-Road 17 09-05-2009 08:41 AM
Whats Best Truggy Out? Kausekaos Nitro Off-Road 28 08-10-2009 03:53 PM
