Old 09-18-2009, 07:51 AM   #16
Frank L's Avatar
Trader Rating: 148 (100%+)
Originally Posted by Integra View Post
I will 2nd that....Vibrational harmonics are KILLER's on servo's....the Pot's and solder joints do not like being rattled around so much.....
madweazl 20 year's ago....we didn't have the technology we do today and the motor's were Nothing like that are now a days.....more then double the power which will equate to more vibration...its just the way thing's are.
Frank L you never used to run the Grommts did you ?
i know there were a couple stubborn guys who have said it to me over the years...but cant remember if you were one of them or not.
Yep I never use to run them until. Went through 6 throttle servos in 2-3 months. Then I was willing to try anything and when a losi team driver tells you to do something yo usually listen. So from now on I use them.
Old 09-18-2009, 10:34 AM   #17
R/C Lidz's Avatar
Trader Rating: 53 (100%+)
Send a message via MSN to R/C Lidz
+ YouTube Video
Josh Langness
RC8T/ OS Speed/ 2060
RC8/ OS Speed/ 2060
FTGT/ MT12
BLitZ/ Castle SCT
R/C Lidz is offline   Reply With Quote
Old 09-18-2009, 11:04 AM   #18
RJNicholson's Avatar
Frank,
I see that you have the carb on your speed pretty straight. Are you running like this on the buggy too.
I was but kept having way to much chassis flex and was tearing carb boots left and right where the carb housing starts at the end of the boot. I was rubbing my top mount on the center diff because the carb was to straight and was like 2mm away from the diff mount.
I had to angle mine, and it doesn't stick at all, but I'm not to fond of it being angled.
Anyone else have this problem?? I was thinking of shaving the top back corner of the diff mount a little bit.
*Team Terribles*
Rigs Listed Below
Losi 8IGHT 2.0 B/BCE Chassis/OS VZB *Sleeper*/RE11/JRHV Servos/KHZ
Losi 8IGHT 2.0 B/Werks B7 Pro/2013/Hitech HV Servos
Losi 8IGHT 2.0 E/Mamba Monster ESC/Xcelorin 2100kv or NEU Castle 2650kv *RIP-LIPO FIRE
RJNicholson is offline   Reply With Quote
Old 09-18-2009, 01:18 PM   #19
Integra's Avatar
I remember telling you Month's ago that Hard mounting wasn't the smartest idea.....but it takes a team driver for you to try it....hrmm.
Originally Posted by RJNicholson View Post
Frank,
i shave my center diff mount enough so that i can get a good line on the carb pull and not have it touch when extreme chassis flex happen's....i also ran the Matrix Concepts chassis for quite some time and i can tell you it has Significantly more flex next to a stock 2.0 chassis....nearing Double the flex if you had to measure it.
here's my linkage on buggy...pics aren't directed towards the angle of the carb...but either way you can see how strait the linkages are.
Old 09-18-2009, 02:15 PM   #20
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Default Servo 8T2.0
Trust me I went through two expensive servos my linkage and setup were correct along with EPA set points very expensive mistake took integra advise and installed rubber grommets on both servos.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 09-19-2009, 06:31 AM   #21
dadsvtechonda's Avatar
bump
Proud Supporter Of WWW.READYROLLERS.COM
(thanks for all the support rome couldn't do It without you)
Losi 8ight T 2.0 Alpha S852 (Orange Head)
www.hobbyhut.com
dadsvtechonda is offline   Reply With Quote
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 05:57 PM
8ight 2.0/8ight-T 2.0 Servo Saver Arm shanty140 Nitro Off-Road 25 03-10-2009 07:22 PM
8ight 2.0 vs 808 vs O'Donnell jpas Nitro Off-Road 66 10-14-2008 09:31 AM
