Old 09-17-2009, 12:42 PM   #1
Default Engine temp 300+. Help.
I just got a Picco .28 P3 and in the process of breaking it in. The engine temps keep climbing, about a degree a second till I kill it when it goes over 300.
The needle settings were at factory but I turned the HSN needle out from flush about 2 turns to richen it for break-in. There is plenty of smoke coming out of the pipe, with occasional fuel drips. Idle is about 1mm open. I am using 20% nitro, and a R5 plug. What can be wrong?
Thanks!
un4gvn is offline   Reply With Quote
Old 09-17-2009, 12:45 PM   #2
losi_racer's Avatar
Trader Rating: 25 (100%+)
did you seal it before running it?
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 09-17-2009, 12:46 PM   #3
Had a similar problem.
It turned out to be the battery in the temp gun. Change the battery first. If it still reads the same then try a second device.
DESC410r-MMP/3800
DEX 410-Tekin rs Pro/6.5
M11x
1day is offline   Reply With Quote
Old 09-17-2009, 12:49 PM   #4
No... What part do I need to do to seal? Thanks.
Old 09-17-2009, 12:50 PM   #5
are you sure your temp gun is not reading in Celsius
300 degrees Far = 148.8 degrees Celsius
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 09-17-2009, 12:56 PM   #6
I thought that could be it too but the screen displays 'F after the reading.
Old 09-17-2009, 12:58 PM   #7
losi_racer's Avatar
i dont get where your going at with that post? he said its reading 300. If its 300c he is screwed
Old 09-17-2009, 12:59 PM   #8
It's a new MIP temp guage, so the battery's new. I'll have to borrow someone else's temp gun and compare.
Old 09-17-2009, 12:59 PM   #9
smokinu's Avatar
Trader Rating: 60 (98%+)
if infact it did run 300 degrees its time to change those bearings!
richen the high speed needle a 1/2 turn and start again.
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 09-17-2009, 01:00 PM   #10
smokinu's Avatar
those things are not worth a penny!
get a duratrax infered temp gauge they are like 20 bucks, and are only like 10 to 15* off an exergen temp gun.
Marcus P.
Old 09-17-2009, 01:34 PM   #11
You did not understand but he did so thats all that matters
Old 09-17-2009, 02:56 PM   #12
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
We need to get him and Dreaux together, one is running hot and the other one is cold !
Do the spit test on the head and see how long it takes to boil off, if it is 300°
it will go quick.
Mugen Seiki \\ Dialed RC \\ Tekin \\ SMC \\ AVID\\ AKA \\ Futaba
OfnaJoe is offline   Reply With Quote
Old 09-17-2009, 03:34 PM   #13
houston's Avatar
Trader Rating: 91 (100%+)
it will go quick.
i would guess low fuel line pressure or head is not torqued properly
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 09-17-2009, 05:13 PM   #14
Low fuel pressure may be it. When I pop open the tank, sometimes it stalls. Is this cause of low fuel pressure?
Old 09-17-2009, 05:27 PM   #15
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
If it does it again take a little spit and put it on the cooling head. If its to hot it will quickly sizzle off. If it just evaporates quickly its perfect. If it takes a while to go away its to cold. Temp guns can be thrown off by shiny stuff. I know alot of guys at the local tracks who use the same method I do.
If you got steady some coming out of track corners then you should have it somewhere in the ballpark. Try the low end setting maby?
awdcameolsx is offline   Reply With Quote
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
engine break in mjnp06 Nitro Off-Road 19 11-17-2007 09:33 PM
Newby Engine Temp Question isthisnameinuse Rookie Zone 9 07-29-2007 12:53 AM
