Old 09-17-2009, 05:44 PM   #16
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by un4gvn View Post
Low fuel pressure may be it. When I pop open the tank, sometimes it stalls. Is this cause of low fuel pressure?
you did say it was just breaking in right ?
low to no fuel will be a cause of overlean cond.
major air leak is not good either
wouldn't think a new engine would have major air leak but with some manufacturers you just never know . i suggest befriending a local with excellent rc problem solving abilities
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 09-17-2009, 05:47 PM   #17
I've always broken in my engines wih a hot plug. ANyway perhaps your HSN is very lean, compensated with a fat LSN.
does the engine flame out between low-mid throttle BTW?
cheapskate.brok is offline   Reply With Quote
Old 09-17-2009, 06:24 PM   #18
Yep, just breaking it in. I guess this extreme heat-cycling would help in the process! I just took it out of the car and applied some permatex on some of the o-rings in case it was an air leak. I also noticed that as the temps went up, idle increased with it... Yeah, local help would be great about now...
un4gvn is offline   Reply With Quote
Old 09-17-2009, 06:31 PM   #19
The HSN is way out from flush. I kept richening it but didn't seem to stop the increase in temps. The LSN was left at factory position. The engine did not flame out as I opened the throttle, but it did cut out a few times when I let go of it.
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
engine break in mjnp06 Nitro Off-Road 19 11-17-2007 09:33 PM
Newby Engine Temp Question isthisnameinuse Rookie Zone 9 07-29-2007 12:53 AM
