SHUTTING OFF YOUR ENGINE >
Old 08-31-2009, 05:21 AM
offroad racer's Avatar
Questions?? SHUTTING OFF YOUR ENGINE
Which is better for your engine? Shutting it off by sticking something in the tuned pipe and then putting the fly wheel in bottom dead center or moving the flywheel with your shoe and then putting the flywheel in bottom dead center?
offroad racer is offline
Old 08-31-2009, 05:26 AM
elkman's Avatar
Default 2nd option
I always touch the flywheel with my shoe or screwdriver handle. I watched the pros at Rc Expo this year in Pomona and they all did the same. I believe that plugging the exhaust just blows out seals faster that not doing it that way.
elkman is offline
Old 08-31-2009, 06:35 AM
PTP Racing's Avatar
Stopping the flywheel is the best way.
PTP Racing is offline
Old 08-31-2009, 08:02 AM
What about pinching off the fuel line?
cassidy is offline
Old 08-31-2009, 08:10 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
Stopping the flywheel is best because any of the other methods will either flood the motor (blocking stinger or carb) or starve it (pinching fuel line) both of which will make it a bit harder to start the next time.
wingracer is offline
Old 08-31-2009, 09:20 AM
fatdaddy's Avatar
if the car is just ideling ill just stop the flywheel with my finger. trying to get your shoe into the hole is too much a pain in the butt.
if its run away, hold in down on the ground and plug the exhaust
fatdaddy is offline
Old 08-31-2009, 09:27 AM
JoeyTheRocket's Avatar
Stopping the fly wheel with a shoe is the best, it has no effect on the motor except stopping it.
Finger over a hot pipe??? not good
Cutting the fuel to the motor, is cutting the lubrication off & kills plugs.... not good
Finger over the carb, kills the plug & dirt can get in easier.... not good
JoeyTheRocket is offline
Old 08-31-2009, 09:38 AM
fatdaddy's Avatar
its a good idea to always wear gloves when youre pitting, and marshaling
fatdaddy is offline
Old 08-31-2009, 10:01 AM
Brandon_oma#692's Avatar
Do you when you are driving?
Brandon_oma#692 is offline
Old 08-31-2009, 10:53 AM
fatdaddy's Avatar
no
fatdaddy is offline
Old 08-31-2009, 11:01 AM
PTP Racing's Avatar
I just bought some gloves for marshalling but I still aint sticking my fingers anywhere near a flywheel. Ive seen more than a couple times people destroy their fingers. I hate to say it but if you have a run away and your counting on me to shut your engine down your in bad shape. I'll hold it on the ground if I can catch it until someone comes and shuts the engine down but I am not risking injury...sorry.
Old 08-31-2009, 11:12 AM
fatdaddy's Avatar
ive gotten my finger chewed up once when i tried to stop a runaway by putting my finger on the flywheel (for some reason i was thinking the gloves wouldnt get torn through by the flywheel ) i knew better before hand, but in the heat of the moment i wasnt thinking properly
and besides, i never said anything about putting your gloved finger on the fllywheel for a run away. only if its idleing. reading is fun
also, if you have gloves on and you catch a runaway and just hold it there waiting for somebody else to stop it. youre retarded. stop being a pussy and turn the car off.
fatdaddy is offline
Old 08-31-2009, 11:20 AM
PTP Racing's Avatar
I never said you said to stop a runaway with your gloved fingers
You can ruin your gloves and fingers and I'll be the pussy with all my fingers. I need them to make a living
Old 08-31-2009, 11:23 AM
Echelon's Avatar
then use ur shoes instead...
Echelon is offline
Old 08-31-2009, 11:29 AM
Zerodefect's Avatar
I just park my car, walk off the driverstand, pick up my car, and dump it on my starter box. Somewhere in there it should have stalled or run out of fuel.
If the thing isn't done by then I just put my finger over the pipe.
Zerodefect is offline
