Old 09-16-2009, 06:09 PM   #1
Default Droop Settings
Hello all, I'm fairly new to the suspension tuning world, at least in RC trucks. I was wrenching on my Z01T, getting it set up to Scott Cramers set-up ( thanks Scott) and I saw the droop setting is "bottom of eyelet." I have no clue what this means or how to set it. What I 'believe' i do know, is droop is set so that you won't strain your shocks, which seems easy enough, but I'm sure theres more too it, seeing as how you need the right downtravel to keep the tire planted. Could someone help me learn how to set it? You don't have to tell me what setting to use, just help me understand the pros and cons, and i have that base setting if I can figure it out! You sure dont have to do droop settings on anything i own with two wheels
ALPINEX is offline   Reply With Quote
Old 09-16-2009, 06:16 PM   #2
Trader Rating: 43 (100%+)
take the shock loose from the tower and pull em away a little then crank the droop screw until the bolt touches the bottom on the eyelet on the cap, repeat for all shocks. you should have to compress the shock just a little when you put em back on the tower.
www.coyotehobbies.com-Owner
Brian Alderman is offline   Reply With Quote
Old 09-16-2009, 06:23 PM   #3
Zerodefect's Avatar
Sounds like a poor way to set droop!
I've tried useing shock length to measure over and over due to trying others posted setups that used shock lenght instead of actuall measured droop under the hubs.
measureing under the hubs I usually find about 2mm error in droop settings when useing shock length.
Zerodefect is offline   Reply With Quote
Old 09-16-2009, 06:27 PM   #4
Gearhead racer's Avatar
What is the best way to set droop??
"Seeing the world on 2 wheels"
Losi Ten-T SCTE~Tekin SC4X 4.5~ Tekin RX8
Gearhead racer is offline   Reply With Quote
Old 09-16-2009, 06:31 PM   #5
just explaining to him how scott cramer does it, which is whos setup hes looking at. i use a hudy station and i set mine like i said above, once i did that i used my hudy ride height tool to measure on the hubs as well.
Old 09-16-2009, 07:28 PM   #6
Zerodefect's Avatar
Set your chassis tires off on 30mm hudy blocks. Need a t flat surface like a cutting board. Slide the Hudy droop gauge under your wheel hubs. -1 or -2 is what I usually run.+/- .5mm
Problem is you need the bottom of your car to be flat. So a brand new car won't sit on the gauges flat because the screws stick out a little. Have to wait until those chassis screws get worn flat if your going to be as picky as me with setup.
Old 09-16-2009, 09:52 PM   #7
Problem is when the screws have worn the chassis is no longer flat. Mine twist & cant be made flat like a onroad car. Its still the way I do it though.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
rc8t droop settings SPARTAN300gt Nitro Off-Road 6 01-21-2009 08:33 PM
Droop settings fruitland04 Electric On-Road 15 11-17-2007 05:15 PM
droop settings Team-RTR Australian Racing 13 10-21-2004 03:36 AM
Droop Settings? grymg Electric On-Road 16 09-23-2004 01:23 AM
