Old 09-16-2009, 05:01 PM   #1
HVAC25000's Avatar
Trader Rating: 19 (100%+)
Default Diff oil vs Shock Oil
Hey guys, what's the difference between the 2? Diff oils seem to be from around 500-50,000cst, and shock oils are like 10-100weight. What's a cst and what's a weight? Can shock oils be used in diffs? If so, what does say a 50wt convert to in cst?
Chris
HVAC25000 is offline   Reply With Quote
Old 09-16-2009, 05:25 PM   #2
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
There is no difference between diff and shock oil other than viscosity. Certain companies use certain ratings for both shock and diff oil. US-based companies like AE and Losi, rate their oils in weights. Many overseas companies like Mugen and Xray rate their oils in cst.
For example, 400cst shock oil is approximately equal to 40wt.
50,000cst diff oil is approximately equal to 5000wt.
However, different brands that are rated at the same viscosity may not actually be the same. Associated 40WT, for example, is equivalent to Losi's 37.5WT or something like that.
Did a quick google search and found this:
http://www.twf8.ws/php/tip/shock.html
I actually remember reading that awhile back.
K_B is offline   Reply With Quote
Old 09-16-2009, 05:26 PM   #3
HVAC25000's Avatar
Thanks!
And sent you a PM.
Old 09-16-2009, 05:28 PM   #4
http://www.twf8.ws/php/index.php?opt...per&Itemid=175
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 09-16-2009, 06:32 PM   #5
wingracer's Avatar
Trader Rating: 23 (100%+)
500 is shock oil. About 40wt.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 09-17-2009, 06:29 AM   #6
osis's Avatar
Talking about shock/diff oils,is there any other site (the GE site is no more)that can do the oil mixing equations.Cheers
osis is offline   Reply With Quote
AE vs LOSI Diff Oil brofroe Electric Off-Road 11 06-23-2009 05:54 AM
T3 vs Rustler T3MAN Electric Off-Road 11 08-26-2005 08:28 PM
777 sp 1 vs. XB8 Breakin2 Electric Off-Road 28 12-15-2004 08:57 AM
Losi Hydra fluid vs silicon diff oil kufman Electric Off-Road 6 08-09-2004 04:17 AM
Unespected handling due to shock oil change - please explain Cole Trickle Electric On-Road 59 01-11-2004 12:00 PM
