Old 10-01-2009, 03:17 PM   #61
noR
noR's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to noR Send a message via MSN to noR Send a message via Yahoo to noR
Originally Posted by az00lude View Post
775 motor runs fine for 4s. It is rated for up to 18v. 550 only rated to 14.4v
Yeah, I was more concerned of the Amperage.
WingWrecker's above advice about stick w/the 2.2A Lipo for the losi starter box motors.
Wondered how that'd apply to 750's mainly.
I think I got it... maybe.
Check out my local track --> http://trackseeker.lefora.com/2009/05/01/trackseekers-18-scale-offroad-track-04302009/page1
noR is offline   Reply With Quote
Old 10-01-2009, 03:22 PM   #62
az00lude's Avatar
I run ofna with 2 775 on gel cell. It will turn over any motor. Don't really need to go lipo IMO. Save you some money for other things.
Specs for 775:
http://banebots.com/pc/MOTOR-BRUSH/M5-RS775-12
Xray xb808
az00lude is offline   Reply With Quote
Old 10-01-2009, 04:43 PM   #63
WingWrecker's Avatar
Originally Posted by noR View Post
But wasn't this about LiPo batteries?
I've been thinking of taking two 2s packs and wiring them in parallel.
Wiring two 2s packs in parallel will only double the mah capacity, leaving you with a higher mah 7.4v power source.
You'd want to wire two 2s packs in series to get the voltage that a starter box requires.
Most starter box's are already wired for a series connection to be used with 2 Nimh batts and would require no changes if using tamiya connectors. If switching to deans, just resolder one lead at a time, leaving the circuit as it was.
8ight 2.0 RTR - 350 w/Turbo Head - Re11 - 4 Shoes - Ace servos - AKA tires
WingWrecker is offline   Reply With Quote
Old 10-02-2009, 06:43 AM   #64
noR
noR's Avatar
Awesome, thanks for that link az00lude.
And thanks for that correction WingWrecker.
Gotcha now.
Help me pick a engine for my Losi 8ight eagle_talon Nitro Off-Road 26 07-19-2008 05:36 AM
MBX5T loaded to the gills!!!!!!!! F/S F/T jldjlaudio R/C Items: For Sale/Trade 29 06-13-2008 11:56 AM
JLR Ofna 1/10th Sedan Starter Box BigPapa Nitro On-Road 19 02-27-2008 04:51 AM
