Old 09-16-2009, 10:02 AM   #16
Lonestar's Avatar
springs sticking out at the end of the shoe = manageable
springs sticking out of the shoe where the shoe makes contact with the bell = time to buy new shoes
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 09-16-2009, 10:41 AM   #17
Check out the VP Clutch systems.. Good pricing, and a wide range of clutch options for Losi, Associated, Kyosho, Mugen, Hobao, Jammin, Xray, and more.
www.vp-pro-usa.com
Andrew Smolnik is offline   Reply With Quote
Old 09-16-2009, 11:57 AM   #18
[QUOTE=Integra;6353044]All Alum set-up can wear on the bell...but Steel VS Alum...the steel will win EVERY time.....you can overheat the shoes and they slag out leaving Massive amounts of Alum on the bell...but if you have the proper stall and shoe compound the alum should never build up slag and the bell should always be the same I.D.
I had this problem with the last pair of shoes I tried. I assume proper stall is refering to when the clutch engages? would too soon or too late of an engagement cause this? I was using 1.0 at first then switched to .9 for springs and that didn't seem to help much. the shoes lasted about a gallon until they were completely gone. Everything from the collet to the bell were new when I first started running them.
AsSc8 is offline   Reply With Quote
Old 09-16-2009, 05:54 PM   #19
Are you sure they are on in the right direction???I've been running chainsaws for 22 years for a living and still catch myself putting the chain on backwards.
Joey Platinum is offline   Reply With Quote
Old 09-16-2009, 10:25 PM   #20
tc5 man's Avatar
i havent used all alum setup on my eight i run 2 carbons and 2 alum,i ran the stock losi alum shoes and they dont last long and they mushroom everytime
now that could be though cause i was running the stiff spring the silver one so that might of cause the wear factor and also once the engine ran hot
i would try the gold on the alum ,i have the gold on my alum now and it seems smoother and i know the shoes shoulnt ware as fast,and i just put the dynamite max life shoes on the clutch and they look good no mushroom on the sides of the shoes etc ,if u do decided to use 2 carbon/alum try the green on the carbons not gold or the black which i think is proberty way to soft
Old 09-16-2009, 10:26 PM   #21
tc5 man's Avatar
and also dont overheat the carbons
Old 09-16-2009, 10:42 PM   #22
Matthijs's Avatar
get this setup: http://www.amainhobbies.com/product_...lutch-Kit-34mm
more and more racers are using it, and liking it very much. Alu shoes with almost no slip and wear. Combine it with a mugen 5 clutchbell and your set! And no, I'm not sponsored by these guys ;-) product sells itself but is new on the market.
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 09-17-2009, 04:23 AM   #23
zonda's Avatar
wow that clutch set looks the shizzle! Thanks Matthijs take it this clutch will fit my GO 5 port and my hyper 7 pro?
does amain post worldwide ? im in UK.
will have to wait just a few weeks before I get this new clutch Im sorting out my electric cars now just before I go back to University. Thanks for all the input and help.
will try this system see how it goes.
would this clutch bell do the trick ?
http://www.amainhobbies.com/product_...lutch-Bell-13T
or should I try a vented one ?
zonda is offline   Reply With Quote
Old 09-17-2009, 06:12 AM   #24
Matthijs's Avatar
that's the right clutchbell. If you are in the UK you can order direct from the manufacturer, JVD: http://www.jvd-rc.com/index.php?page...&group=4&cat=4
It is sold in the USA under the label of Ascendency with a black colouring.
Old 09-17-2009, 06:40 AM   #25
Integra's Avatar
comp's Do NOT need any more stall then green or black..,..gold all your doing is exactly as your trying to avoid...heat/slip.....run green on comp and gold on alum and you will have a clutch that lasts gallons not tanks.
Losi clutch probs piranha21 Nitro Off-Road 28 09-04-2009 12:34 PM
WERKS Clutch TNHEADDUCK Nitro Off-Road 15 08-15-2009 04:10 PM
What Clutch Bearings Do You Use? Frank L Nitro Off-Road 60 07-22-2009 02:43 PM
Endless Clutch Problem: HELP! Krawl Nitro Off-Road 23 03-12-2009 07:01 AM
CLUTCH ISSUES buckeye34 Nitro Off-Road 22 05-09-2008 07:38 PM
