Old 09-14-2009, 06:05 PM   #1
Madbrad's Avatar
Trader Rating: 29 (100%+)
Default Receiver battery care NiMh
Should the battery be discharged after each time it is used? I used them almost every weekend, or at most every two weekends. I am using NiMh batteries and now have a nice charger that can dischage and i can chose the rate at which it discharges. Thats brings me to the 2nd question. At what rate should they be discharged ?
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 09-14-2009, 06:08 PM   #2
freestylinmotox's Avatar
No a NIMH battery does not need to be discharged unless its brand new. If its brand new then you need to cycle it a couple times to bring it to life if need be.
As for the discharge rate, its whatever you want it to be. Preferred would be anywhere from 1-5 amps depending on the charger
when in doubt, throttle out! braaap!
freestylinmotox is offline   Reply With Quote
Old 09-14-2009, 06:17 PM   #3
What's the nominal Voltage before the charger stops discharging it? Thanks!
cheapskate.brok is offline   Reply With Quote
Old 09-14-2009, 11:47 PM   #4
evaa's Avatar
it depends on your setting really, but if i were you i would not let it go beyond .9 per volt, so if its a 5 cell receiver pack then dont go below 4.5 volts total pack voltage. personally i dont discharge my rx pack and they last a long time. just make sure when you feel the servo weaken, stop the car, disconnect the pack, let it cool then charge it.
evaa is offline   Reply With Quote
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
LIFEPO4 RX 6.4V BATTERY COBRARACING Nitro Off-Road 277 04-21-2010 02:01 AM
Lipos vs NiMH......Nicads....Alkalines Ducati-Rider Electric On-Road 38 04-12-2006 06:55 AM
Kyosho FW05R with Novarossi NS3 Murnan Modified TRAJ R/C Items: For Sale/Trade 17 12-15-2004 05:29 PM
