Old 09-15-2009, 06:09 AM   #16
Trader Rating: 15 (100%+)
I have ran about 14 gal since last nov. Raced all over from Central Oh to ATL Ga. I run truck only. I have slowed down lately in the peak season probably 15-20 hrs a week of work doing whatever. 75% of your success is how well prepared your are. And in my opinion there is no substitute for track time. Making sure ur prepared is key to being able to make setup changes and feeling the difference the changes make. If you come to the track chasing a motor or screws are coming out, then you really don't feel motivated to try anything, all the more reason for having good dependable equitment.
Jonathan Bell is offline   Reply With Quote
Old 09-15-2009, 06:20 AM   #17
PTP Racing's Avatar
Ive only been able to race 13 times this year (frequent bad weather) and am just finishing my 5th gallon. Admittedly I dont practice much at all or use a lot of fuel breaking in new engines but I do finish 95% of all my races and run many long mains.
Between races I spend on average probably 5-6 hours cleaning and preparing but if I cut the TV off I am certain I could cut that down to 2-3 hours. Mostly I just clean and check over. I do diffs or shocks around every gallon of fuel or so but mainly base that on the importance of the race I will be attending or if I expect track conditions I may not be setup for. I regularly replace clutch bearings and air filters between races but have been known to occassionally push them multiple races if they look good enough.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 09-15-2009, 07:08 AM   #18
Im right at 10 gallons since March - I run pro most of the time. I run a Losi 8T 2.0 OS engines - i practice about 4 hours a week and wrench between 8 and 12 hours a week - depending on the level of race is coming up. My truck is ALWAYS clean and ready to go, except on Mondays. ( tear down )
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 09-15-2009, 11:18 AM   #19
Tech Legend
Wild Cherry's Avatar
3 gallons , maybe a bit more
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 09-15-2009, 11:28 AM   #20
madweazl's Avatar
Just got back into the hobby. I used maybe 1/4 gallon on Saturday with about an hour of practice time and 25 mins of race time (should be typical of my average week) in the sportsman class for a total of 3/4 gallon this year . I typically rip the car apart on Sunday and spend about 4 hours on maintenance provided nothing needs replaced.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 09-15-2009, 12:02 PM   #21
houston's Avatar
Trader Rating: 91 (100%+)
couple hundred
i sell byrons
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 09-15-2009, 12:08 PM   #22
ON A MISSION's Avatar
Trader Rating: 32 (100%+)
Default fuel
with that stuff you might !! HA ha Houston
ON A MISSION is offline   Reply With Quote
Old 09-15-2009, 12:10 PM   #23
houston's Avatar
see ya in october ?
i texted ya a while back dude !
Old 09-15-2009, 12:12 PM   #24
elkman's Avatar
Default Been a light year
2 gallons of Odonnell, 2 gallons of Trinity and 6 gallons of Byrons (which I now use exclusively thanks to Monty)
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 09-15-2009, 12:13 PM   #25
Razathorn's Avatar
I'm on gallon #6 for the year. Just got my v-spec pinched and reconditioned at rayaracing.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 09-15-2009, 12:14 PM   #26
elkman's Avatar
AMEN! I believe that it's closer to 90%. I finished way higher in some mains just because other people's cars crapped out. I am a huge believer in preventive maintenance (Comes from my aircraft maintenance background)
****RUSH****
Old 09-15-2009, 12:17 PM   #27
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
im on my 6th gallon of fuel now this year. 3-4 of it was o donnel when i first started racing and the rest is byrons. i just switched to it not too long ago.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 09-15-2009, 12:19 PM   #28
Razathorn's Avatar
Same here. Every week I wipe/lube my drive shafts, lube the front/rear ring/pinion, inspect the clutch, and replace any bearings through the entire car that need it. I also re-surface my brake discs / reset brake balance as needed and replace any leaking exhaust gaskets.
Old 09-15-2009, 03:48 PM   #29
jmackani's Avatar
Trader Rating: 14 (100%+)
Just curious, what's everyone paying for their fuel? I am on about my 10 gallon this year. LHS is selling S&W 30% for $37. Sounds high to me which is why I am asking.
jmackani is offline   Reply With Quote
Old 09-15-2009, 03:55 PM   #30
Talking
ok I had to check with my sponsor to get a accurate count because I had no idea. I have ran 14 gallons since Feb. we sale 30% byrons for $35.99
Hot Bodies, Proline, Byrons Fuels, Hitec, Amain.com, Protek, Samurai, Avid Bearings, Dialed, Venom Rc, Advantage racing products.
PUDDIN is offline   Reply With Quote
