ninja a compression
ninja a compression
I had a vspec before my ninja. And when my vspec lost compression it was pretty dramatic. You could turn the flywheel by finger pretty easily once it broke in. Stayed like that for 5 gallons.
Could you expect the same out of a ninja since it's o.s. based? Got about a gallon and a half and it's loosing up quite a bit.
bump
I will get my Ninja in the mail tomorrow, so hopefull in 9 gallons, I'll let you know. 7 to 9 gallons are the norm on this engine, so I hear at my track.
Location: SO. CAL. Thunder alley, revelation raceway The Dirt -Perris RIP OCRC
It has a coated crank and its one of the best motors ever made .I'm braking one in as we speak... sounds like its ready to rip just keep it clean and not crazy hot and it will be fun to drive....
Rex
I have over a gallon in it and it will barely get warm. Is it the 20% should i take a shim out?
i have the ninja bo1a with the lightened head. got a little ever a gallon on it right now. no way i can turn the flywheel over by hand as it sits in the car. need it out to turn it over by being able to grab the flywheel this motor has MAD compression. after a gallon of fuel and starting to lean it out i am SCREAMING around the track getting a little over 9min on a tank and running temps right around 230. this is all in a Mugen MBX6 and i love it
BEST MOTOR I HAVE EVER OWNED
hey reggie l... i see in your sig that you are running the ninja with the EB Mods head button. how do you like that combo? what is the noticeable differences?
